| Chip Amps Amplifiers based on integrated circuits |
#12 |
Then how about parallel 2 x TDA7293 for one channal with the same transformer? Since add one more amp PCB still far much cehaper then buy a new transformer or speakers....... but as told before, I have 2 transformers in hand both rated at 150VA / 25 x 2, will 150VA enough for parallel 2 x TDA7293 per channal?
#13 |
all the power from the transformer must be heatsinked in the amplifier and dissipated in speakers voicecoil
your suggested case is small, heatsinks probably too and I don't know what your bookshelf speakers can withstand therefore there is little to gain from more transformer wattage try one transformer for stereo, you already have it!
| Gate Drive Transformer | microsim444 | Everything Else | 1 | 2nd December 2008 12:52 PM |
| Wnt. 2x35v minimum 500VA toroid transformer | gaborbela | Swap Meet | 2 | 26th May 2008 02:44 AM |
| using LME49810 to drive multiple TDA7293 ? | rcownie | Chip Amps | 7 | 28th November 2007 06:09 PM |
| Can you drive two rails from one transformer output? | preiter | Power Supplies | 7 | 26th May 2006 03:46 PM |
| What’s the minimum power transformer required to build a gainclone amplifier? | Katapum | Chip Amps | 23 | 4th December 2005 09:47 AM |
| Page generated in 0.05245 seconds (81.07% PHP - 18.93% MySQL) with 10 queries |
