| Chip Amps Amplifiers based on integrated circuits |
I need current draw of an lm3785, lm3886 and lm4780 (as used in PCBs sold by Peter and Brian). I want to use a CLC filter in the supply but I do not know how much current is required by the chip.
Thank you ps. I looked at the datasheet and I cannot find it. |
#2 |
the input current is roughly equal to the output current. If your amp is capable of 50W into 8r0 then peak voltage is 28.3Vpk. The peak output current is based on the effective impedance of the load and the shape of the drive signal. Continuous sinewave signals will send Ipk=Vpk/Z for a normal speaker then Z can vary from about 60% of nominal impedance to about 10times nominal impedance. For discontinuous signals with fast stopping or fast starting the effective impedance can drop as low as 35% of nominal impedance. The worst case current is Vpk/nom imp/0.35=28.3/8/0.35=10Apk The worst case input into that 50W amp is about 10Apk from either supply rail. Most of this peak will be met by discharging the main smoothing caps fitted to the supply rails. Any added resistance between the amp and the rectifier will reduce the peak current ability. Your CRC will rely on the last C to supply the peak demand with a little help from any on board decoupling.
regards Andrew T. |
#3 | |
thank you very much for the extensive reply Andrew. helpful as always ps. I wouldn't have figured that out myself
| calculating total current draw | woodturner-fran | Tubes / Valves | 3 | 9th March 2008 12:11 PM |
| Current rating and tube current draw | cbutterworth | Tubes / Valves | 1 | 13th October 2006 05:42 AM |
| Do CLC filters work well at low current draw? | leadbelly | Solid State | 2 | 28th March 2004 01:51 PM |
| current draw on a gainclone? | cowanrg | Chip Amps | 9 | 9th August 2003 07:58 AM |
| Opamp current draw | 5th element | Solid State | 2 | 21st July 2003 01:11 AM |
| Page generated in 0.08502 seconds (74.37% PHP - 25.63% MySQL) with 10 queries |
