| Chip Amps Amplifiers based on integrated circuits |
#11 |
never mind about the power output for 99% of the time. Two things are MUCH more important. 1.) what is the quiescent power that your sinks must dissipate? 2.) what happens to the signal/output power in the other 1% of the time?
regards Andrew T. |
#12 | |
And linear control will give less risk of electrical noise than switching/PWM control. |
#13 |
If you can hear the fan coming on over all that music, it's an audible warning that the amp is getting hot and maybe the user should check something!!
regards Andrew T. |
#14 | |
Keep in mind this is a bedroom amp that will be pumping out a half a watt 99% of the time. The fan noise would be distracting at that level. I could 'merge' the two circuits so the fan initially turned on slowly and then ramped up as the sink temperature rises. That may be overkill for this application but I love the concept. Oh, I don't think electrical noise will be a problem as the fan circuit is behind regulators. |
#15 | |
A few findings from the quest for silent forced-air cooling
#16 |
I have to agree with AndrewT.
Forget the numbers for a moment. If you are listening to music low in volume enough that you can hear the fans, something is wrong! I would seriously consider larger sinks with verticle fins.
Poor stereo mix? Switch to mono! Perfect. |
#17 | |
diyAudio Moderator Emeritus
Fan noise (particularly the BPF and its harmonics) is also enhanced by unsteady/uneven loading on the fan. This basically means you want to avoid flow obstructions at the inlet and outlet of the fan for the quietest operation. Normally a minimum desired distance for obstructions from the fan blades is about one half the overall diameter of the fan.
Brian |
| Samsung 1602VFD For CDROM Controller & Remote Volume Controller | slowgay | Swap Meet | 2 | 22nd November 2008 02:44 PM |
| fan-based cooling for chipamp | oldfatbubba | Chip Amps | 9 | 16th August 2007 01:20 AM |
| fan cooling? | Raj1 | Pass Labs | 22 | 8th January 2003 02:33 PM |
| Cooling an amp with poor cooling | BAM | Solid State | 8 | 31st December 2001 04:40 AM |
| Page generated in 0.10115 seconds (78.24% PHP - 21.76% MySQL) with 11 queries |
