Old 8th July 2007, 08:30 PM   #1
Vidi is offline Vidi  Norway
Default Parallelling two LM 3876 for sub
Hi!
I want to build a simple amplifier to pull my 4ohm subwoofer
(ie I want to build an active sub, the crossover is allready made).
The power of the amp should be at least 100w in 4ohm, and I were wondering if it is possible to parallell two LM 3876 to archeive 112w in 4ohms? And if so, is it just to build two identical amps, and connect them together with two current sharing resistors like the datasheet for LM 4781 describes?
PS: If someone else are looking for an active crossover for subwoofer, take a look on this: http://lcaudio.com/index.php?page=27
Regards Vidar
Old 9th July 2007, 12:49 PM   #2
yes, just follow the datasheet.
Do ensure adequate heatsinking. Try for almost doubling the minimum recommended for the voltage and load. Keep in mind you have to cool two chipamps.
regards Andrew T.
Old 2nd November 2010, 10:43 AM   #3
navin is offline navin  India
navin's Avatar
Send a message via MSN to navin Send a message via Yahoo to navin
I have built a 3876 stereo amp PCB as per the design posted on ESP's project 19 (see link) Single Chip 50W Stereo Amplifier.
Is there anyway I can bridge the outputs to produce 60-80W rms @ 8 ohms (the power supply I intend to use is +/- 25VDC to ensure that the chip is protected).
...still looking for the holy grail.
Old 2nd November 2010, 10:54 AM   #4
to get 80W into 8ohms from a bridged arrangement you need two amplifiers capable of 40W into 4ohms.
regards Andrew T.
Old 2nd November 2010, 11:05 AM   #5
navin's Avatar
Yes I know that. As per the Overture design guide with 24VDC I should get 40W rms per channel @ 4 ohms (stereo) from a pair of 3876. What I need to know is how do I SIMPLY bridge the ESP Project 19 circuit to produce 80W (mono @ 8 ohms) from a pair of 40W (stereo @ 4ohms) amplifiers.
http://www.national.com/vcm/national...gn_Guide15.xls
http://www.national.com/vcm/national...sign_Guide.pdf
Old 2nd November 2010, 11:25 AM   #6
Do you know?
40W into 4r0 (a resistor) requires the amplifier to output ~4.5Apk to the load.
Which National chipamps can guarantee that performance when operating at Tc>40degC?
40W into a 4ohm speaker requires an output current of at least double that 4.5A value.
Expect speaker demand on transients to be <=9Apk to <=13Apk.
How many paralleled chipamps do you need to guarantee meeting that performance?
I don't think you do know.
regards Andrew T.
Old 3rd November 2010, 05:50 AM   #7
navin's Avatar
I figured since the PS will be 24VDC the current will be limited to safe limits.
according to this link the 3875 (and I assume 3876) can deliver 4A
LM4780 / 3886 / 3875 / 1875 Comparison
LM3876 parallel into 6ohms. Possible?
Old 3rd November 2010, 06:39 AM   #8
navin's Avatar
Do you know?
I was thinking of something like Figure 5.2.1 in the PDF below
http://www.national.com/an/AN/AN-1192.pdf
The heatsink I am using has 50% more area than of the one shown in figure 9.1.
Old 3rd November 2010, 01:54 PM   #9
that is the problem that you do not seem to appreciate.
Your speaker demands current. Your amplifier tries to meet that current demand.
If your amplifier cannot meet that demand then it clips. It can be voltage clipping or current clipping, the effect is the same. As you turn up the volume the amplifier sends a distorted signal to the speaker.
All National chipamps are severely current limited. The highest output I am aware of is the 3886 which has 7Apk available when Tj=Tc=25degC.
As soon as the chip temperature rises above this, the protection triggering levels are reduced to prevent damage to the chip.
National sell millions of chipamps to drive 8ohm speakers.
National use BPA style topologies to sell tens of millions more to drive unsuitable loads.
An lme498xx with 1pair of MJL4281/4301 will at least match and probably better the performance of a 4chip BPA assembly.
Chipamps suit higher impedance loads and suit higher efficiency loads.
They do not perform well into low impedance, low efficiency loads.
regards Andrew T.
Old 4th November 2010, 07:22 AM   #10
navin's Avatar
Do you have a schematic for the 498xx/MJL4281/4301? BTW I was not looking at a 4 chip BPA but just bridiging 2 chips. My "subwoofer" is a small 7" woofer from Wavecor SW182BD01_02 so I do not need more than say 50-60W rms. So I figured 60W/8 ohms = 8 amps and 2 3876 can deliver 4 amps each for 8 amps. Maybe I was naive.
Maybe a safer option is to use the 3886 instead. Unfortunately I cant find the 3886 in Mumbai, India.
Why is 3876 rarely used by folks in this forum? goering Chip Amps 6 2nd September 2004 06:59 AM
Parallelling transformers for more power? Optical Chip Amps 16 23rd December 2003 07:53 AM
Parallelling O/P in P3A richeros Solid State 7 28th January 2003 07:52 PM
lm 3876 impressions Jean Solid State 35 17th August 2002 05:09 AM
Page generated in 0.10816 seconds (80.84% PHP - 19.16% MySQL) with 10 queries
