...brought into this world at about 12:30 AM EST
LM3875 with dual regulated supply using LM338
also see...
http://home.comcast.net/~eric.erickson/gainclone/gainclone2.JPG
http://home.comcast.net/~eric.erickson/gainclone/gainclone3.JPG
http://home.comcast.net/~eric.erickson/gainclone/gainclone4.JPG
feedback is always appreciated...
Bubba
also see...
Bubba
Thank you.
The source is a homebrew tube preamp. It's a simple, SRPP topology using 12AU7s (or whatever variant that happens to be handy). It has clean DC on the filaments and a regulated power supply.
Here are the guts....
http://home.comcast.net/~eric.erickson/gainclone/preamp2.JPG
The signal caps are Multicaps but the rest of the parts are mediocre. Regardless, it sounds good.
DocLorren said:Very nice layout with short signal paths. Do you like it?
Thank you kindly for the compliment, Doc. So far yes, I like it a lot. I'm a bit surprised how good it sounds, really.
I'm thinking about making a top cover from tempered glass and using 1/4" spacers for ventilation. Thoughts?
Bubba...
I like the idea of a glass top. If you listen at moderate levels, you will probably not have a problem with heat. IMHO your heatsinks are on the skimpy side. So, beware of trying to reproduce rock concerts in your living room.
Are you new to gainclones? If so, you have a pleasant surprise in store. The burn in period! The sound will get sweeter and more "musical'.
Cheers!
Cheers!
davidlzimmer said:IMHO your heatsinks are on the skimpy side.
Perhaps, but they barely got warm after 12 hours. I was somwhat worried about the size of the regulator heatsinks but they were even cooler!
davidlzimmer said:Are you new to gainclones? If so, you have a pleasant surprise in store. The burn in period! The sound will get sweeter and more "musical'.
This is the first Gainclone though I've build several tube/valve based power amps, though.
RE: burn-in, what do you recommend? I was contemplating either:
1) using a signal generator at, lets say 1 kHz,
2) tuning between two FM stations,
3) pink noise software such as....
http://www.sharewareconnection.com/test-tone-generator.htm
davidlzimmer said:IMHO your heatsinks are on the skimpy side. So, beware of trying to reproduce rock concerts in your living room.
I think those heatsinks are fine - I have some of those myself. But, on my LM3875 GC, I use only an aluminum angle and mine barely gets warm at moderate levels.
Nice job Bubba!
No no no!
Good music and your fav beverage!
The fun is noticing the subtle difference!
kec said:I think those heatsinks are fine
Well, I just ran about 18 watts of noise through 8 ohm resistors for an hour and the heatsinks got hot, but not to the point where I couldn't touch them. Ditto for the regulator sinks.
Next step - run 30 watts through 4 ohm resistors. THAT should be interesting....
Hartono said:Very neat , uncluttered without being over the top with expensive case material, congratulations !! and looks very good.
That perforated board supply is very neat ! I with I could do perforated board that looks that good.
Hartono
Thank you for the compliment!
BWRX said:That will probably make the sinks very hot or too hot to touch.
After the last experiment, I'm afraid that might be the case...
Do you have any thoughts where I could purchase a larger sink?
barred_boss on ebay has some great heat sink material at a very low price. I'd highly recommend looking into getting some of it for your amp.
Here's a link to one of his auctions: http://cgi.ebay.com/HEATSINK-ALUMIN...ryZ31489QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Also, the orientation of the heat sink as you have them now is not optimal. The fins should be running up and down (for the best convection cooling) instead of side to side. In other words, rotate the heat sinks 90 degrees and see if that makes a difference.
Thanks for the recommendation. I also found this....
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=270142453620
- Chip Amps
- new gainclone w/ reg supply (pics)
