Old 5th January 2012, 07:40 PM   #21
What exactly is this preamp supposed to do? How much voltage gain and how little noise do you need? (I can tell you right away that feedback Rs in the hundreds of kOhms make a good noise and distortion generator. A 10k resistor has 12.6 nV/sqrt(Hz) of voltage noise, scaled to other values via sqrt(R/10k).) What kind of input signals and loads would it have to handle?
Jumping into building the thing is kinda pointless if you haven't thought of the specs first. I suggest you read this so you get an idea of how the pros do it.
I dunno what's supposed to be wrong with a LM317/337 setup. (The above example got away with bog standard 78xx/79xx jobs, albeit lower-noise ones, and still noise and power supply rejection performance of the finished unit is very good.) A "low-noise" config (electrolytic at the adjust pin and all) gives perfectly acceptable noise levels and regulation for anything that has ever heard of PSRR (and audio opamps tend to have at least 30 dB across the audio band at 20 dB gain, more at lower frequencies). Just make sure you use a good grounding layout, as not having one may reduce regulator performance to very modest levels.
Old 5th January 2012, 07:42 PM   #22
Originally Posted by sgrossklass View Post
........... may reduce regulator performance to very modest levels.
Or would it be more accurate to say "very immodest levels"?
regards Andrew T.
Old 12th January 2012, 10:19 AM   #23
hi,
if I use LME49710HA for each channel, would it make any improvement building two +- shunt regs? or one for both opams would be enough?
Old 13th January 2012, 12:06 PM   #24
thanks!
Old 17th January 2012, 04:17 AM   #25
If u make dual mono instead of stereo, it is always better.
Gajanan Phadte
Old 17th January 2012, 09:56 PM   #26
thanks!
I think I would stay with two LME49710HA and single +-12v PS.
Old 18th January 2012, 09:01 PM   #27
again another question regarding power supply
it appears that 100nf of fkp-2 is huge value, 10nf could be easily found, while 100 is smth rare...
Should I stay with other fkp-2 value or use some other cap in PS equal to 100nf besides 1uf mks and 100uf elko?
Old 19th January 2012, 04:43 AM   #28
The values shown in the design r a result of spice simulation and best sound, if I am not wrong. U should try them but u can always alter the values for convenience but it will be a compromise.
Gajanan Phadte
Looking for some NS LME49710 Single DIP Opamp dtm1962 Swap Meet 0 4th September 2008 12:06 AM
LME49710 missing data in datasheet peranders Parts 19 15th May 2008 05:27 AM
LME49710 -- new passive RIAA Circuit jackinnj Solid State 7 18th July 2007 09:19 AM
WTB:LME49710 and LME49740 Ryssen Swap Meet 5 4th June 2007 08:38 PM
Page generated in 0.08762 seconds (77.26% PHP - 22.74% MySQL) with 11 queries
