| Chip Amps Amplifiers based on integrated circuits |
hello...i was wondering what will happen if i use 2*30V / 5A toroidal transformer for the TDA7294 amp..becouse in the schematics it says that we need transformer (xxVA) CENTRE TAPPED....well this is the problem...can I use my toroidal or I must buy C.T. transformer??
tnx here are the schematics |
#2 |
your twin secondary can be converted to a centre tapped by joining the two windings in series.
regards Andrew T. |
#3 |
ok...and the I get something like +30V 0 -30V ??
and what current do I get now.... 5A + 5A or just 5A...but 60V ? |
#4 |
don't worry about the current. You have selected the transformer size based on VA rating and this is adequate. BTW, the VA rating should be between 1*maxmimum power output to 1.6* max power for classAB amplifiers. ClassA amplifiers need quite a bit more between 3*max power to 6*max power. Your selected transformer is 30+30 * 5=300VA, this is ideal for a total power output of 200W or 100W +100W for a two channel amplifier. A 30-0-30Vac or 30-0 & 30-0Vac transformer with a rectifier and capacitor input filter will give about +-44Vdc. You are in the chipamp Forum, will your chipamp survive this voltage? If the mains input rises to maximum tolerance then @ +6% the PSU will send almost +-47Vdc to the amplifier.
regards Andrew T. |
#5 |
ok TNX
I'm trying to use TDA 7294....it operates on +/-50V I thik it will survive.. ![]() becouse the trafnsformer is from antother chip amp...TIP142 + TIP147...(200W music power_100W RMS) |
#6 |
TDA7294 spec says +-50Vdc no signal +-40Vdc max operating Your transformer is for a 100W into 8ohm amplifier, this chip is not that.
regards Andrew T. |
#7 |
ok.... thank you very much for the information... |
#8 |
I use 2 center taped transformer 12x2 connecting them in series
24x2 =48 |
#9 |
If you try the TDA7293 Chip (pretty much the same as the TDA7294) it can handle +/-50V (+/-60v No Signal) ....The chip should also cost the same and work in the same PCB...
Cheers |
#10 |
well as you mention double transformers 12x2 how I should connect them to get 48v?
| Transformer question? | mcameron | Parts | 5 | 23rd January 2005 07:52 PM |
| transformer question | xcortes | Chip Amps | 0 | 31st October 2004 05:04 AM |
| Transformer Question | TunaFish | Tubes / Valves | 15 | 18th June 2004 11:20 PM |
| Transformer Question | toque_101 | Chip Amps | 2 | 26th January 2004 05:21 AM |
| Page generated in 0.09533 seconds (79.20% PHP - 20.80% MySQL) with 11 queries |
