| Chip Amps Amplifiers based on integrated circuits |
What is the maximum power you could expect to get from a LM3886TF assuming extremely good cooling?
Judging by the datasheet with a 40V supply, you should be able to get a little over 80W into an 8 ohm load. Has anyone tried this? What's the highest continuous wattage anyone has ever reliably attained and measured? Also, has anyone ever burned one out trying for high power? Any answers from anyone who's actually tried it would be best. No suggestions to use the T please... I know it's better thermally. I want to know what can be done with the TF (I have lots) ![]() Anyone tried sanding them? -Nick |
#2 | |
diyAudio Moderator Emeritus
Brian |
#3 | |
Electrons are yellow and more is better!
If you are interesting in high continous power youmust use the T model.
/Per-Anders (my first name) or P-A as my friends call me |
#4 |
Sadly with these chips, when you reach a certain power threshold, the THD figures goes to hell... (look at datasheet) As with most chips I think the result is best at about half of the max figure...
#5 |
the worst case condition into a non reactive load is not maximum power. In fact testing to maximum into an 8r0 load should never break a properly designed amplifier. Half power is worse for chip stressing. Reactive loads are much worse for chip stressing. If you want 60W into a real speaker then you should be aiming for 50 to 60 degree phase angle. This is worse than halving the resistive load value. What I am suggesting here is that your 60W into 8ohm amp MUST be capable of 100W into 4r0 as a minimum spec for driving an 8ohm load. If you have 4 to 8ohm speakers, that resistive test load becomes 2r0. Now try that through a TF package (using a cold sink and for less than 1second).
regards Andrew T. |
#6 | ||||
![]() Quote:
-Nick |
#7 |
half power might be very common (or even predominant) for an amp driven to clipping on low dynamic range material. Then the heating could be beyond any chipamp to heatsink interface.
regards Andrew T. |
#8 | |
A good reason to avoid clipping. |
| My first try for LM3886TF | pra3718 | Chip Amps | 14 | 11th September 2009 06:18 PM |
| Lm3886tf | smflash | Chip Amps | 16 | 1st May 2009 01:37 PM |
| My high power LM3886TF | senicz | Chip Amps | 18 | 21st April 2008 01:51 AM |
| Wtb: Lm3886tf | mantisory | Swap Meet | 0 | 6th July 2006 08:50 PM |
| Page generated in 0.09591 seconds (82.17% PHP - 17.83% MySQL) with 10 queries |
