Old 4th July 2007, 07:04 PM   #1
ddoyle is offline ddoyle  United States
Default dead amp
Advice? just picked up a pair of PSB powered sub's,(Century SubSonic 2i) one works great, the other dead. Fuse blows right away. Pulled the amp, looking it over looks like the op amp center pins are burnt. It is a LM324n, dont see anything else wrong. Worth getting fixed? What would be the most common cause for this to burn up? A bit of a novice at this level, any input would be helpful.
Dan
Old 4th July 2007, 08:37 PM   #2
just a couple suggestions, not guarantying anything but if you are just going to throw it away you might as well try something (you cant break garbage right?). Those "Center Pins" are the supply pins to the chip
http://pdf1.alldatasheet.com/datashe...EMI/LM324.html
Try desoldering and removing the burnt op-amp, save this part just in case you do take the unit in so the techs can see what pins burnt. once the opamp is removed carefully look at the board and see if you can find any solder blobs or loose metal that could have shorted the pins and caused the chip to blow. Now try powering up the unit,
if the fuse doesn't blow we are making progress. measure the holes where the chips used to be with a multimeter, pin 4 on the chip (Vcc) and then measure pin 11 (Vee or GND) if there is another LM324 on the board reference that to see if the pins have the same voltages.
if the fuse still blows well then there is probably a short circuit somewhere. If you can disconnect the power supply section from the main board do so but be careful not to allow wires to short out each other. see if the fuse still blows (you may need a couple fuses )
if you can take some pictures of the circuit board(s) it would help.
good luck
Dave
Old 5th July 2007, 04:14 AM   #3
Thanks Dave, will keep you updated.
Dan
Old 5th July 2007, 03:04 PM   #4
Called PSB svc cntr, new amp, $500! Pulled board out, closeup exam no signs of something causing short. Did find 2 blackened areas on soldier side of board(TIP29c and TIP30c) transistors?
Dan
Old 5th July 2007, 04:17 PM   #5
can you take some pictures of the boards? Its kind of hard to say what is wrong without a schematic or picture. If those tips are output transistors it may be possible that the output terminals were shorted and caused that transistor to blow. you really do need to check voltages to see what is happening.
Old 6th July 2007, 04:58 AM   #6
seem to be having a bit of trouble attaching the pictures, I will figure it out!
Dan
Old 6th July 2007, 04:54 PM   #7
you can sign up at photobucket.com then add your pictures there and then link them in your post
Old 6th July 2007, 11:59 PM   #8
Arx is offline Arx  Canada
Those sound a little small to be output transistors on a sub. 1A 60V
Maybe a couple dozen watts tops into a 4 ohm load. Judging by ohms law and without looking at the datasheet, which probably gives plenty of other limitations.
I'm guessing they're part of the regulation or something.
-Nick
Old 7th July 2007, 12:22 AM   #9
Excellent point Nick. I guess i shouldn't think out loud. By the way if they are used for voltage regulation it would help explain, well not explain but add reasoning to why the supply pins on the lm324 are burnt as well. Would be able to make a more educated guess with schematics or Pics
Old 8th July 2007, 04:13 PM   #10
Thank you all. Tried the photobucket for the pics. Also got some service info from PSB. They had trouble with the voltage regulators failing due to ac line voltage increases. Looks like that is what happened here. Both low voltage regulators burnt, also took out the LM324 and a 1N5347. Not sure about the 2 mosfet's yet. I need my DVM from work for better testing.
Dan
http://s201.photobucket.com/albums/a...t=DSCF0634.jpg
Dead AKG P 8E with X 8S R Bernhard Analogue Source 10 2nd April 2008 11:55 AM
Dead Amp?? Shim Solid State 12 5th June 2007 05:00 PM
Nak mb-70 dead ? MadMutt Car Audio 10 5th April 2007 04:18 AM
is my amp dead? :( torxim Car Audio 5 18th September 2004 11:37 AM
Page generated in 0.11688 seconds (79.02% PHP - 20.98% MySQL) with 10 queries
