| Chip Amps Amplifiers based on integrated circuits |
what current rating fuse should be used before the power section powering a tda2050?
#2 |
what supply voltage are you planning? What speaker impedance do you intend using?
regards Andrew T. |
#3 |
15-0-15 trafo providing around +/-20V into 8 ohm speaker
#4 |
Did it Himself
Ohm's law says I = V / R
So I = (20 x 0.707) / 8 = 1.77 amps Use a 2A fast/quick blow fuse
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#5 |
you might get away with F1.6A in the supply rails after the main smoothing caps. These fuses would allow continuous peak currents of about 3.2A to flow to the speaker. That is equivalent to 40W into 8r0, way above what this proposed amp can send into an 8ohm speaker.
regards Andrew T. |
#6 |
the reason i asked is i gutted a tda2030 commercial amp and it had a 160ma fuse, can anyone explain this?
also, i plan to have the fuse before the traffo. |
#7 |
AGH!!!
mains fusing is a different ballgame.
regards Andrew T. |
#8 |
so what fuse rating ?
#9 |
Did it Himself
Ipri = (Idc / 0.62) x (Vsec / Vpri)
= (1.77 / 0.62) x (30 / 230) = 0.372A So use 400mA slow blow / time delay
#10 |
2A will do.
| Tda2050 | Jpoole908 | Vendor's Bazaar | 0 | 1st June 2008 06:34 PM |
| TDA2050 parallel. HELP! | Matthewong | Chip Amps | 5 | 9th March 2006 03:47 AM |
| Tda2050 | Mr. Triatic | Solid State | 8 | 26th April 2004 06:00 PM |
| Page generated in 0.07263 seconds (85.31% PHP - 14.69% MySQL) with 10 queries |
