| Chip Amps Amplifiers based on integrated circuits |
I'm looking for like 100 wpc at 8ohms or at least about 60 ish. Whats a good GC board I can get that will let me achieve this? Also are these class A? or Class A/B?
#2 |
chipamps are definitely not ClassA. They may be ClassAB but since the internal design is inaccessible we can only guess. Most chipamps can give a maximum of about 50W to 60W into a mildly reactive load. If you want 100W you will need to parallel a pair of chipamps. If you want to drive loads lower than 8ohm you should consider paralleling if you want near maximum power.
regards Andrew T. |
#3 |
Have you compared the sound much to a Class A mosfet based amp? Just curious how they compare?
#4 |
Is the 3886 or 3875 capable of 50-60 watts?
#5 |
diyAudio Moderator Emeritus
Yes. Have a look at the part datasheets at www.national.com
Brian |
#6 |
Or try the BPA.
#7 | |
Custom analogue The amplifier is in biased as class A right up until the final ouput stage, which is quasi. I dont know enough to say if this is true, but I believe what I read generally |
#8 |
You might find something suitable at http://www.41hz.com/
Some of their kits use surface mount components, which might be hard to solder. |
#9 |
Yeah I saw those. I think I'm gonna go with a SS design. Probably the F4 do 2 stereo set's to get 100wpc at 8ohms full class a.
#10 | |
That's what ClassA will look like!
regards Andrew T. |
| What makes the good guitar pickup sound so good? | darkfenriz | Instruments and Amps | 15 | 1st March 2009 11:46 PM |
| Good switch for Stepped attentuater, Good cheap RCA jacks | pjpoes | Parts | 20 | 10th March 2005 08:47 PM |
| Pioneer TS-W304C- anyone have good design for it? and is it good for home sub? | XteveX | Multi-Way | 7 | 28th April 2004 04:05 AM |
| Page generated in 0.09100 seconds (79.04% PHP - 20.96% MySQL) with 10 queries |
