Old 29th June 2007, 07:36 PM   #1
Default input impedance LM3875
Hello diy members,
How can I increase the imput impedance of my Audiosector LM3875 amp , now it is 22Kohm. Can I get problems with dc offset
All info is welkome
Old 29th June 2007, 08:10 PM   #2
Default Re: input impedance LM3875
Originally posted by Diy martin
Hello diy members,
Just change the 22kohm resistor at the input(input to ground)
When you rise the input impedance,offset will go up a few mv.
Old 29th June 2007, 08:26 PM   #3
justblair's Avatar
How much do you need to increase it by?
Old 1st July 2007, 08:57 PM   #4
To match my passiv crossover I will need about 100k imput impedance.
Old 1st July 2007, 09:04 PM   #5
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
An op amp buffer would work well for what you want to do.
Brian
Old 1st July 2007, 09:33 PM   #6
justblair's Avatar
Or visit Decibel dungeon and have a look at some of the discrete buffers in buffered gainclones
Buffereed gainclones
NUUK has gathered a few there, designs that you will find on other sites plus Nicks listening experiances of them.
You should find something that you like.
Old 1st July 2007, 11:11 PM   #7
passive crossover comes between the power amp and the drivers.
The input impedance is irrelevant to this.
What impedance can your source feed?
regards Andrew T.
Old 1st July 2007, 11:28 PM   #8
Davey is online now Davey  United States
Well, not necessarily. There are a number of passive line-level crossover options that might work well. Maybe that's what he has in mind.
Raising the input impedance of a power amplifier would tend to minimize circuit interaction with the crossover network.
Davey.
lm3875, dc on input ? Jaap Chip Amps 1 5th February 2009 07:24 PM
0.300 VDC (from soundcard) on LM3875 GC input !!! Leglandu Chip Amps 28 1st February 2008 03:39 PM
Input Impedance Bengali Analog Line Level 7 15th August 2007 10:24 PM
Input impedance nhuwar Tubes / Valves 24 23rd July 2007 11:11 PM
Can I omit the input resistor for the LM3875? sardonx Chip Amps 8 31st July 2005 11:18 PM
Page generated in 0.08260 seconds (76.35% PHP - 23.65% MySQL) with 10 queries
