Old 27th June 2007, 05:58 PM   #1
jumpus is offline jumpus  United States
Default Noisy 3886
I'm having problems with a recently constructed 3886 amp. There's substantial hum when power is on, and even more if nothing is connected to to the inputs. Also, noise reduces dramatically when power is cut to the transformers, but the amp is still running (on power stored in the supply capacitors?).
I'm thinking the noise is from the transformers, and is making it's way into the signal path through the signal's ground somehow, but I'm just a beginner with this stuff.
What else could the problem be/ how can I fix it?
Thanks!
Old 27th June 2007, 06:21 PM   #2
gootee is offline gootee  United States
Hi Kenneth,
Hum is one of those things that usually depends on exactly how everything is connected, and layed out.
So you would probably get better advice, sooner, if you could post a photo of your setup, and a schematic, and as much other relevant information as you can.
There are a lot of people here who will like to try to help you, if they are given enough information.
- Tom Gootee
http://www.fullnet.com/~tomg/index.html
Old 27th June 2007, 07:25 PM   #3
I will put a picture or two up when I get a chance. I just wanted to see if my idea makes any sense. I'm at work right now, so the picture(s) won't be around for a while. Could the symptoms that I described point to anything? I understand if a picture is necessary for any concrete determinations of the problem, but I'm running low on things to do here (at work) and I could really use something to think about.
Old 27th June 2007, 08:03 PM   #4
There are some good threads in this forum about solving hum and grounding problems, which are often related.
I don't know what kind of power supply topology you have used. So it's very difficult to make any specific statements, or even guesses, about it. But I can make a couple of general statements, that might give you some food for thought.
You should use what is called a "star" ground-return setup, in which all major ground current-return paths are run in separate conductors, which all meet at only ONE point (often the ground side of a main filter capacitor in the power supply). This is done because wires and PCB traces have parasitic resistance and capacitance, across which voltages are induced (back at the end of the conductor that's farther from the power supply, in the case of ground returns), by currents, which makes sharing of ground return paths "a bad thing".
Also, typically, the power supply and audio grounds, which usually are connected to each other only at the star ground point, are either not connected to the "earth ground" from the power cord, at all, or, are connected to it through a "disconnect network", which might include (all in parallel) a >= 10 Ohms resistor, a 0.1uF or so cap, and two opposite-facing diodes.
Old 27th June 2007, 09:11 PM   #5
You might want to first check how your input connectors are grounded. If they are grounded to the case, that could be the problem.
Also, AC wiring should be kept well-away from signal and DC wiring (and components). If that's not possible, they should cross only at right angles to each other. It might also help to twist any pairs of wires you might have.
- Tom Gootee
Old 27th June 2007, 09:20 PM   #6
Thanks for the advice. I'm going to re-assess the situation when I get home...12 minutes to go...I'll get a picture up for you then.
Old 27th June 2007, 09:45 PM   #7
Originally posted by gootee
You should use what is called a "star" ground-return setup, in which all major ground current-return paths are run in separate conductors, which all meet at only ONE point (often the ground side of a main filter capacitor in the power supply). This is done because wires and PCB traces have parasitic resistance and ***capacitance*** , ...
I MEANT to type *** inductance*** (although there is also some capacitance between any two conductors, which depends on the materials and geometries involved).
- Tom Gootee
Old 27th June 2007, 10:26 PM   #8
Pictures, as promised. Kinda big files, but good resolution so you can zoom in real good. Let me know if a smaller file would be better...
Old 27th June 2007, 10:45 PM   #9
Trying this again....
File Type: jpg f7ca217c-519a-4ef8-b5d6-99487c85424f.jpg (14.3 KB, 402 views)
Old 27th June 2007, 11:05 PM   #10
a bit higher quality
File Type: jpg f7ca217c-519a-4ef8-b5d6-99487c85424f-1.jpg (56.1 KB, 385 views)
Noisy ADC 5th element Digital Line Level 6 30th August 2009 10:29 PM
Noisy PSU? pftrvlr Tubes / Valves 16 2nd July 2007 06:26 AM
Noisy NAD 705 squirrel69 Solid State 6 7th April 2006 01:37 AM
noisy noisy noisy noisy noisy tube dsavitsk Tubes / Valves 50 20th February 2006 04:07 PM
Impressions of Snubbered BrianGT 3886 vs Reg 3886 moving_electron Chip Amps 1 23rd March 2005 06:51 AM
Page generated in 0.10806 seconds (80.54% PHP - 19.46% MySQL) with 11 queries
