My first DIY build vacuum tube style Gainclone.
Old 27th June 2007, 02:41 AM   #1
pinoy82 is offline pinoy82  United States
Thumbs up My first DIY build vacuum tube style Gainclone.
Bought the kit from EZamps website, its another Gainclone using LM3886 and the DIY step by step instructions are very easy to follow but I substituted the resistors with Vishay and Caps I used Cerafine also upgraded the NE5532 OPamp to LM4562. So far i'm impressed with this amp it sounded very good driving an 8 ohm ONIX XLS speakers, the detail, imaging and clarity on mid and highs are amazing.
Specifications:
Power Output: 4 ohms 50WRMS, 8 ohms 38WRMS
Bridge Power: 8 ohms 100WRMS
THD+Noise 0.012%
S/N Ratio: <-92dB below 1W, 8Hz-20kHz
Average DC Offset: <1mV (Tempco Compensated)
Frequency Response (-3dB points): 8-50kHz +/-0.1dB
Instantaneous DC Offset: 0.0009V
PCB: 4.2 x 3.0" Double sided, silkscreened
Heatsink: 2.38 x 4.56 x 0.9" Black Anodize 6061 Aluminum
Old 27th June 2007, 02:42 AM   #2
Default PointZero Back Photo
Back of the amp.
Old 27th June 2007, 02:45 AM   #3
Default Point Zero Power Supply
Power Supply
Old 29th June 2007, 08:21 AM   #4
neeraj is offline neeraj  India
Nice Looking Amp pinoy.
Neeraj
Old 29th June 2007, 08:39 AM   #5
impsick is offline impsick  United States
impsick's Avatar
why vacuum tube style?
"Nothing happens for a reason. There are just reasons why things happen." Quote me on that. http://stores.ebay.com/AudioGrade?_rdc=1
Old 29th June 2007, 08:40 AM   #6
Hartono is offline Hartono  Indonesia
outboard
edit: at first I also tried to look for the tubes.
Old 29th June 2007, 08:43 AM   #7
impsick's Avatar
oh ha ha i got it
My first DIY build vacuum tube style Gainclone.Hide this!Advertise here!
Vacuum tube tester, do you own one? fernando_g Equipment & Tools 87 13th November 2016 03:47 AM
Homemade Vacuum Tube dhaen Tubes / Valves 50 13th July 2011 06:48 PM
S3E Vacuum Tube angsuman Tubes / Valves 12 15th March 2008 06:12 AM
Vacuum Tube Pre O.C.L. gianmaria Tubes / Valves 13 16th February 2006 07:32 PM
DIY Vacuum tube amp turbo_h4 Tubes / Valves 2 1st July 2004 02:48 AM
