Old 27th June 2007, 01:14 AM   #1
panson_hk's Avatar
Question Direct WM8816 to differential current output DAC
I want to make a DAC using TI DSD1792A and WM8816 as volume control. Is it possible to directly connect WM8816 input to DAC Iout+ and Iout- (one WM8816 per channel for balance control). Anyone tried before?
Old 27th June 2007, 02:31 AM   #2
banana is offline banana  Hong Kong
Hi Panson,
There might be several possible methods to connect WM8816 with Iout DAC.
Connect Iout to LMO/RMO, and LFO/RFO to gnd, use the variable resistor as passive I/V. The ideal of passive I/V is where IC designers and diyers divided. DAC appnote aways oppose to passive I/V, but some diyers prefer it.
Connect Iout to LMO/RMO, use the external opamp as I/V and the variable feedback resistor as active volume control. This seems like more feasible way to go.
Since 1792 output a lot of current, u only need a few hundred ohms for full output. However, WM8816 datasheet didn't mention range of the internal feedback resistor. U might need to add resistor accross LFO/LMO (RFO/RMO) to bring down the output level.
Old 27th June 2007, 03:31 AM   #3
panson_hk's Avatar
Thanks for your suggestions!
I prefer active approach. However, your idea just uses part of the control. It seems there is a variable resistor at LIN/RIN. Do you think the control range affected? Zero crossing detector is bypassed too.
Old 27th June 2007, 04:34 AM   #4
I have no experience with WM8816. And you're right, bypassing the zero crossing detect would cause problem.
Maybe u could make it the other way, connect Iout to LFO/RFO and opamp output to LMO/RMO instead.
Gain range can be scaled by adding external resistor. But the scale might not be perfect logarithm anymore.
Old 27th June 2007, 05:03 AM   #5
panson_hk's Avatar
Thanks!
Differential Amplfiers - current sources under/over the triodes audiowize Tubes / Valves 34 27th January 2012 02:50 PM
Differential output Keruskerfuerst Analogue Source 3 18th July 2007 12:25 AM
Building A Direct Output Line For An Amp MrGuitardeath Instruments and Amps 11 30th October 2004 06:39 AM
Can amplification based ta3020 amplify direct current signal? green3002 Class D 0 14th October 2004 06:01 AM
Grid current and direct coupling jeff mai Tubes / Valves 18 29th July 2003 11:11 PM
Page generated in 0.06669 seconds (75.69% PHP - 24.31% MySQL) with 10 queries
