what preamp do you use with your chipamp?
Old 26th June 2007, 01:12 PM   #1
jarthel is offline jarthel  Australia
Default what preamp do you use with your chipamp?
if it's a DIY, can you point me to the schematics?
Thank you for the replies
Old 26th June 2007, 05:33 PM   #2
john blackburn is offline john blackburn  United Kingdom
I use the "Uno" design from Decibel Dungeon with my Chipamp.com LM3875 and FR125s
http://myweb.tiscali.co.uk/nuukspot/...clonepre2.html
Its my first amp build and has been in "test" mode for 3 months now with only one set of inputs, no lid on the case etc. The reason is that I cant bring myself to unplug it and finish it as I would much rather be listening to it!
One thing I will say is that it worked on stripboard first time for me, and I'm new to this stuff so that goes well in its favour.
Old 26th June 2007, 08:31 PM   #3
jaudio is offline jaudio
My favorite,well for now.
http://www.diyaudio.com/forums/attac...amp=1131902668
Old 26th June 2007, 08:49 PM   #4
justblair is offline justblair  Scotland
justblair's Avatar
The Twisted Pear Audio's Kookaburra Pre-amp
I cheated with mine, I went for a kit from Twisted Pear. This is most definately the easy way out. The kit is so simple to build, the components are all labelled to match the silkscreen, the boards are well constructed. No need at all for instructions.
My next project was the DDAC from Doede. Wonderfull kit, but not as easy to build, no component values marked, so a mulitmeter was essential.
Back on to the subject of the pre. The kook has a very nice sound, although now and then I get a little noise when I adjust the volume. I use it staright into my Inverted Gainclone, no caps and the combination sounds magical. I have nothing to compare it to DIY wise yet, but will remedy this soon.
Old 26th June 2007, 10:43 PM   #5
gofar99 is offline gofar99  United States
Greetings, Since I prefer a more mellow sound from my chip, I used a tube preamp. It started out as a kit from Jaycar, but I modified it for better sound and to drive my chip amp. The original had Jantzen caps, but I am building another with Auricaps for comparison. The availability of the kits is dubious, but I listed a source of the boards in a write up I did. See the www.diyaudioprojects.com site and look at the project "Beauty" if you want further info.
I also find that the slightly modified Velleman 8021 preamp I have makes a good driver for the chip amp. It uses a single TLE2071 and only 1 Auricap cap in the signal path.
Good listening,
gofar99
Old 27th June 2007, 12:35 AM   #6
trats is offline trats  United States
mine too
what preamp do you use with your chipamp?Hide this!Advertise here!
preamp for chipamp getafix Chip Amps 1 17th October 2007 11:49 AM
chipamp passive preamp / crossover DoomPixie Chip Amps 4 23rd October 2006 10:13 PM
Preamp specs for a chipamp zenon Chip Amps 13 21st May 2006 01:15 AM
chip preamp for my chipamp? Russ White Chip Amps 3 9th March 2005 04:51 PM
Chipamp as preamp? lumanauw Chip Amps 24 13th May 2004 03:32 AM
Copyright ©1999-2017 diyAudio
