| Chip Amps Amplifiers based on integrated circuits |
Hi all,
Last weekend I've tested my last LM4702 project. As mentioned its a very good and "hot" amplifier. I use that circuit; ![]() With Renesans lateral MOS pairs (2SK1058/2SJ162). And set the bias current at 110mA. I have -4mV DC offset on each channel. No switch on/off pop, hiss noise (even inputz open) or any hearable distortion at listening levels. There is also no input cap as recommended by National guys. Anyway, I am happy with the circuit with that configuration. However I feel the deep basses some weak. My ears accustomed to LM4780 gainclones sound. And this amp has more detailed mid and treble tones. I dont know the reason, but as I heard somewhere when power supply goes to the upper voltages then basses become more weaky. Is that true? And a request, Does anybody may advice a good working preamp or buffer circuit with bass boost option for my amp pls? Best regards, Ozgur
Best regards, Ozgur |
#2 |
Hi Ozgur,
Have you tried connecting some much larger capacitors in parallel with Cs10 and Cs11? By the way: What are your power supply voltages? And what is the output driving? - Tom Gootee http://www.fullnet.com/~tomg/index.html |
#3 |
Yes, in application there are 100uF in parallel to 0,1s..
And in PSU unit there are two 10,000 ESR, 470nF and (2R2+100n for snubberising as Carlos advices) for each rail.
#4 |
My suppply voltages are 40+40 VAC and 55V per rail on DC. The output MOSFETs are 2SK1058 and 2SJ162... If you mean it for "output driving".
#5 |
And this is my PCB design which using for that project.
![]() As you can see, there are 100uF s on each rail input.
#6 |
You might want to test it with caps that are more than 100 uF, there, if you haven't already tried that, and make sure that they are very close to the transistors.
How long are the wires (or PCB traces) from the PSU to the transistors? |
#7 |
Hmmmmm
Do you think this design reduces the bass response? And should I put some larger value caps near to MOSs source pins?
#8 | |
#9 |
I will try that, but not early than this weekend. I will write for the results on Monday.
But what about the input buffer? Do I really need an input buffer? Does it affect the sound quality? Because I read that in many soruces. The voltage gain is enough for (in fact more than enough) CD players output. Thx.
#10 | |
Maybe you could first try a "quick and dirty" input buffer, with a simple opamp circuit on a breadboard or perfboard, just to see if it has any good audible effect. |
| Matching IRF530 for a buffer, some results, but I need advice | justblair | Parts | 4 | 10th July 2008 02:44 AM |
| Bass boosted preamp, suggestions pls... | Dxvideo | Chip Amps | 0 | 10th August 2007 02:25 PM |
| Who has tried a current boosted op-amp (with a transistor) as a chip-amp buffer? | sardonx | Chip Amps | 18 | 19th March 2005 12:23 PM |
| Tube output buffer for DAC....needs advice! | jazzpeter65 | Tubes / Valves | 0 | 4th April 2004 10:48 AM |
| op-amp based preamp advice needed | Adam | Solid State | 11 | 18th November 2002 02:14 PM |
| Page generated in 0.10850 seconds (82.25% PHP - 17.75% MySQL) with 10 queries |
