My work! LM4766 Full balanced
Old 20th June 2007, 09:39 AM   #1
bbp is offline bbp  China
Default My work! LM4766 Full balanced
To build a stereo amp, I plan to use 8*LM4766!
I just finished PCB project with Protel DXP
Each board uses power regulator build with 5-10 mA current source and LM431 (adjust it to 32V)
Here is some PICs about it ,but I have not make real PCB out yet
Old 20th June 2007, 09:47 AM   #2
Default more pics
PCB in 3D
Old 20th June 2007, 09:50 AM   #3
Default sch
my english is so so so poor
Old 20th June 2007, 09:51 AM   #4
Default Pcb
Make this PCB out, and ...
here is the bottom side
Old 20th June 2007, 10:03 AM   #5
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Default Re: sch
I haven't seen any signs of this yet Your english is quite alright.
Are you really usre about the parallel connection? Don't you need any resistors in series as the rest of the world does?
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 20 pcb's in interest.
Old 20th June 2007, 11:37 AM   #6
Default Re: Re: sch
The post#1 shows the real schematic ,and post#3 only shows the theory,not the one I really want to build
On the PCB, I will use 4 * 0.47-1 omega resistors on each board.
Old 20th June 2007, 12:17 PM   #7
Talking PCB is on
here are both the side of PCB
Old 20th June 2007, 12:28 PM   #8
Default PCB2
Get a clear view
Old 20th June 2007, 12:41 PM   #9
peranders's Avatar
Have you really tested to connect the inputs of LM1876 they way you do?
I really suggest you take a look at AN-1192!
http://www.national.com/an/AN/AN-1192.pdf
Old 20th June 2007, 01:02 PM   #10
Default ......
Many thanks for your suggestion,actually I have not test it before,I made the schemartic through my experience,but I will test the circuit later,and then make a report .
My work! LM4766 Full balancedHide this!Advertise here!
Will this balanced PSU work as intended? Will Solid State 4 24th February 2009 09:41 PM
full or half bridge balanced or not? oldroborg Class D 3 18th December 2005 11:08 PM
why o why doesn't this work ? Balanced 549 SpaBlauw Chip Amps 15 26th January 2004 09:06 PM
