| Chip Amps Amplifiers based on integrated circuits |
The main different between the 2 chipamps is that the TF version has an insulated heatsink.
I am wondering whether 1. there are any other differences besides that mention above. I suspect not. 2. difference in sound quality. any inputs from those who has experimented with both. |
#2 | |
diyAudio Moderator Emeritus
Brian |
#3 |
The plastic case is a worse thermal conductor, and because of that the plastic chps have a slightly lower peak thermal output.
#4 |
You have to consider the entire thermal path. When using the chip with plastic case, you do not need an insulator between chip and heatsink, and one less layer of thermal paste. I think in the long run the plastic case is definitely worth it, and thermally will not be much worse if at all than the metal tab version.
Other than the package type, the two chips are identical. |
#5 |
Electrons are yellow and more is better!
If you plan to use +- 40 volts and heavy use, then you must have the "T" version but is it home environment, lower supply voltage, then the "TF" model is to prefer. Easier to mount fewer things can go wrong.
/Per-Anders (my first name) or P-A as my friends call me |
#6 |
Well, as I said, slightly....
I also use TF package and my supplies are +-35V with 8ohm load. |
#7 |
I have all my TF's sanded, removed about 0,2mm. just so far that you cannot see those little round grooves anymore. Maybe, if someone has a defective LM3886TF he could provide some empirical data to see how much is safe.
cheers, Markus
regards / servus |
#8 | |||||
I have run the maximum supply voltage I find NO difference in sound quality between them. The uninsulated one doesn't run much hotter when used on the SAME heat sink. The difference is about 2 degrees when measured with an infrared thermometer using a 1K sine wave with identical testing times Personal opinion here ... I believe that a lot of problems are caused when trying to use heat sinks that are way to small. I have used +-40 volt supplies with a 4 ohm loads without any problems. Mine have spent hours running loads not to mention the cruel beatings they received playing music. |
#9 |
thanks everyone particularly, Burnedfingers for a worthwhile contribution.
#10 |
I have built both too,
I can't find any difference in sound quality between them. |
| 10 pcs LM3886T | daedalus | Swap Meet | 3 | 28th March 2009 04:39 AM |
| Wtb :- LM3886T PCB | poynton | Swap Meet | 7 | 6th September 2007 05:18 AM |
| Lm3886t / Lm3886tf ? | matt09 | Chip Amps | 8 | 9th August 2006 02:38 AM |
| Fs: Lm3886t Lm3886tf | elementx | Swap Meet | 2 | 14th July 2006 05:18 PM |
| Lm3886t | Nobodysfool | Chip Amps | 10 | 22nd May 2006 07:26 AM |
| Page generated in 0.11795 seconds (83.91% PHP - 16.09% MySQL) with 10 queries |
