| Chip Amps Amplifiers based on integrated circuits |
Hello !!
I'm needing a Bi-Amp configuration, and my Solid State amp works with 40+40v. Would be excessive and expensive put another one huge amp to drive the tweeter, so I thought about use an Chipamp to drive the Tweeter. What about the TDA7293 ? How does it sound? Any other suggestion? The loads are 8 Ohms. Woofer is 92Db, and tweeter 95Db, so the tweeter will work with -3db attenuation on the signal, before the amp. The frequency cut is 1800Hz, 24Db/oct Best Regards !! |
#2 | |
The increase in sensitivity of the tweeter will allow a half power amplifier to achieve the same SPL as the mid/bass driver. Some would try a much lower power for the tweeter amplifier, but I always suggest matching maximum (peak) SPLs. This helps avoid clipping of the very fast transients that get sent to the tweeter. But if you want to build a dual channel amp that has a mix of half power and full power amplifiers inside you then need two different voltage PSUs. It is much cheaper and simpler to use the same voltage to power both amplifiers and then you end up with the same voltage drive to each driver. An adjustment of the sensitivity control on the input to the tweeter amp allows setting of the treble you prefer to hear. The type/duration of signals sent to the respective drivers is very different. You may achieve some economy by reducing the continuous power output of the tweeter amp. Smaller faster capacitors will go some way, discrete gives even more flexibility here but not in this thread.
regards Andrew T. |
#3 |
Yes, the crossover will be active, and two amps are necessary to drive both transducers.
I'll power both amplifiers with the same PSU, but as the tweeter is +3Db sensitive, I'll attenuate 3Db on the tweeter's amp input. The easyest way I think. I was wondering what would be better, I think that despite the thoughts, only a good listening test will show which option is the best. 1- Two TDA7293 amps. One for woofer, one for tweeter. -3Db on the signal input of the tweeter's amp. 2- One SS amp (symasym), and one LM3886 amp (with LM338 voltage regulator, as the supply rails are too high to the LM3886 handle), again -3Db on the signal input of the tweeter's amp. 3- This would have the best damping factor and power dissipation. Two paralel TDA7293 to drive the woofer (just to optimize the power dissipation and damping factor), and one TDA7293 to drive the tweeter, of course with a -3Db attenuation on the signal input. That's what I must decide. The SS amp is Symasym, an wonderful amp. LM3886 is also good sounding for HIGHS. Symasym is more dynamic and alive. So, if I decide to go with Symasym because of the sonic quality, I'll use LM3886 for highs that is also good sounding. Theoretically, the best "enginering" option would be go with TDA7293's. What you think? |
#4 | |
I would expect the symasym to outperform the chipamp at all parts of the frequency spectrum. BTW, forget about damping factor, use this ONLY when designing your speaker. Even then the DF effect is quite small and can be more dominated on what is between the PCB output and the driver input.
regards Andrew T. |
#5 | |
Nando, if you have an extra amp only for trebles, you might consider ClassA, nothing beats ClassA for highs. Why not building another pair of symasyms? Mike |
#6 |
Hi MikeB ! Your answer is always well come !
I think that would be a waste build another symasym just to drive the tweeter, much more expensive than a chip-amp. LM3886 when well implemented, performs pretty well with highs, and Symasym would drive the woofer, that is what express that wonderful dynamic, voices, pianos etc. I can consider Class A. The tweeter only needs a half of the woofer power, as it is 3Db more sensitive. How many watts would you expect to drive the tweeter very well with a class A amp? Best Regards ! |
#7 |
A 20W class A amp dissipates about 110W, wow, not possible
#8 |
You might need an extra power supply for the ClassA, +/-20V would be a good guess, giving ~20W into 8ohms. A DoZ might be interesting, quite simple and can be easily modified to symetrical powersupply skipping the outputcap.
Dissipation would be ~40watts. Mike |
| ESP P3A with higher supply rails | Flavio88 | Solid State | 20 | 29th September 2007 10:49 AM |
| 12 - 24V Pre-regulated supply from 35V rails | Nordic | Power Supplies | 27 | 11th December 2006 12:57 PM |
| Regulated supply rails for amp - as big as you want. | Circlotron | Solid State | 32 | 22nd January 2004 01:24 PM |
| Lower supply rails for this amp? | mik | Solid State | 4 | 11th June 2003 10:22 AM |
| Page generated in 0.10613 seconds (79.05% PHP - 20.95% MySQL) with 10 queries |
