Effect of supply bypass positioning.
Old 10th June 2007, 08:13 PM   #11
Arx is offline Arx  Canada
Originally posted by BWRX
How much you put close to the chip depends on a few things - what frequencies will the chip amplify, how much output power do you expect the chip to produce on a continual basis, and of course size/layout contraints. To maximize space you can use 470uF 50V caps that are about as tall as the chips, otherwise I would side with Minion and try to use up to 1000uF 50V per rail. Of course, place any smaller film/ceramic decoupling caps as close to the chip pins as possible.
If you're looking for ruggedness you really should use a PCB.
Size isn't really a problem. I'm more concerned with heat and inertia. Obviously with the chip right beside the heatsink, the capacitors aren't going to be much further away.
Maybe I'll give the PC board a thought, though my heatsink is about 30cm square.
To distribute the 6 chips across the heastink I'll likely want the chips mounted at the edges of the board, on the same plane, so I'll have to bend a lot of pins...
Effect of supply bypass positioning.Hide this!Advertise here!
Effect of Supply noise on oscilloscope bandwidth? Craig405 Solid State 24 11th August 2009 08:50 PM
Partial cathode bypass to effect a treble boost. Shoog Tubes / Valves 4 22nd May 2007 07:34 PM
Effect of Power Supply on Soundstage Width foxyb Solid State 62 13th December 2005 07:00 PM
Want to bypass power supply, but... beanbag Chip Amps 1 17th November 2005 04:47 PM
Best Op-Amp Supply Bypass Scheme psychokids Solid State 3 2nd January 2003 08:38 PM
