| Chip Amps Amplifiers based on integrated circuits |
Hi, as someone who has not built a gainclone as of yet I will be purchasing BrianGTs Stereo Kit with one Power Supply and Two Amp boards.
Now, Ive got a Cambridge Audio A1 in perfect working condition, but I do not really use it and do not like the lack of bass, etc. although the quality is ok. I was wondering if a gainclone would fair better or worse? I would guess better. Another question is wether I could use the existing torrodial power transformer that is in the case. When powered up the output measures 20.9 (21) V. Would this be suitable as an input to the gainclone or not? I believe this would be useful because I could use the input stages built in. Any ideas or feedback very VERY appreciated. |
#2 |
A +/-20V supply will make a very cool running GC. The output power will be abit limited though. (About 2*30W into 4ohms and half of that into 8ohm.) I think that most use about +/-25 to 30V for 4 ohm and up to 35V for 8 ohm.
space |
#3 |
A lot depends on how easy your speakers are to drive. For a similar project, take a look here .
If you find the A1GC lacking in power, you should have plenty of space to fit a larger transformer later!
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#4 |
Thanks ALOT you 2. So 50V on the rails would work for a GC running 8 ohm speakers? no loss in sq?
#5 |
Are you measureing the AC voltage off of the Transformer or the DC Voltage after the rectifier (or regulators) ??
Because 21V DC Might be a Little bit low but still quite useable even into 4 ohm loads, but 21v AC will be about 28v-30v DC which is plenty for a Gainclone.... You should also check that the Xformer supplies enough Current for the gainclone...... You will need close to 2Amps of current at 28v DC for a single LM3886 Chip or about 80vA...... Cheers
#6 |
21VDC sounds a bit low and the output power might be limited.
i suggest you to buy a transformer about 100VA rating and has a pair of 20-0 transformer sec. wiring. |
| cambridge audio cd-6 | chight | Digital Source | 0 | 25th November 2008 05:35 AM |
| Cambridge Audio 340A SE preout conversion and other mods | mikesnowdon | Solid State | 0 | 31st May 2008 08:00 PM |
| Cambridge Audio 640C No audio output PLEASE HELP! | Kajman | Digital Source | 3 | 10th December 2007 09:45 AM |
| 115v conversion fro 230V Cambridge Audio CD4 and Dacmagic 2i | taskerc | Digital Source | 4 | 7th February 2006 07:02 PM |
| NAD Gainclone repair conversion | Rick NL | Chip Amps | 1 | 7th June 2004 12:23 PM |
| Page generated in 0.08160 seconds (77.99% PHP - 22.01% MySQL) with 10 queries |
