| Chip Amps Amplifiers based on integrated circuits |
#82 | |
That is a very interesting idea....
Less pulp more juice Twisted Pear Audio. |
#83 | |
The slew rate limit can also be measured by increasing the frequency until the output is a triangle wave, then measure the slope in V per microsecond. Ccomp influences the slew rate. I just haven't had time to try this with my samples....
Glenn. |
#84 | |
The chip is then protected at quiescent current level until the shunt starts to reduce it's demand to try to keep the supply voltage up, plus peak/transient demand from any supply caps after the CCS. Simple and short circuit proof.
regards Andrew T. |
#86 |
The Cc in the prototype is 22 pF. I then measured some curves using AP S1. The output residual noise is about 45 uVrms (BW = 22 kHz). Several THD vs output level curves are shown in the pdf file (note the input impedance of S1 is 100 kHz). My next step is to load the circuit similar to that of headphone amp.
#88 |
what connections have you got to ground (0V)? The output should be open circuit for checking output offset. Will this chip operate correctly with both outputs unconnected? If you know the ground currents then you can calculate the difference between Icc & Iee. If there is zero ground current, then Icc=Iee.
regards Andrew T. |
#89 | |
Input (IN+) is grounded via Rin. Am I answer your question? Yes, offset was measured with output open circuit. The ground current is 4 mA, exactly the difference between Icc and Iee. Is it normal? |
#90 |
you are getting 4mA flowing into the ground connection from Vcc. Why do National show 2mA flowing out of the ground to Vee? Your input pin ground current <1uA and is swamped by others. Why is your circuit flowing in the opposite direction? Is your 4mA the mute current?
regards Andrew T. |
| Page generated in 0.10450 seconds (79.90% PHP - 20.10% MySQL) with 11 queries |
