| Chip Amps Amplifiers based on integrated circuits |
#771 |
the driver base stoppers are a good safety/stability measure.
Worth adding base stoppers to the outputs as well. You can delete these after testing, or just change the values, depending on results. The 68r runs the drivers at near constant current at very low to zero output currents. Expect ~9mA + output base current as the driver current.
regards Andrew T. |
#772 | ||
I haven't any oscillator for detecting possible oscillation beyond of audio band. I can do only basic measurements, so, can you suggest me to respect the scheme as what it is or can we claim that avoiding these resistors don't touch final sonic result too much? I rather prefer avoiding resistors for simpler circuit. I apologize for asking these silly questions, i'm just trying to understand what is it beyond of these kind of variations. |
#773 |
#774 | |
#775 | |
if the center tap is not connected to the output, driver will not be off. I prefer this one. Regarding oscillation, it does not a matter of the driver output current. You will see oscillation in small signal circuit. It is about gain and phase. If we have base stopper at the output, we may be able to omit the stopper of driver. However, it is also layout/wiring dependent. If test confirms the base stopper can be removed, then take them out in the final version. The base stopper ensure negative resistance never happens. Last edited by panson_hk; 5th September 2011 at 12:09 AM. |
| Page generated in 0.08592 seconds (74.57% PHP - 25.43% MySQL) with 11 queries |
