Old 16th August 2007, 10:39 AM   #101
Originally posted by panson_hk
For current-limited regulator, you proposed a shunt regulator? The chip's Iq is 11/13 mA. If the CCS is set at 50 mA, a shunt transistor will consume about 39 mA x 60 V = 2.34 W in idle mode. Will it be too much?
using a transistor with 10W 100MHz to 200MHz hFE100 to 150 would dissipate your 2.34W using a 10C/W sink at ambients upto 30degC. and Tj still below 90degC.
I have not yet implimented either series or shunt front end regulation so have no opinion which sounds better.
The inherent current limit of CCS + shunt is attractive.
The few papers I've read seem to suggest that noise suppression is better with a good shunt.
regards Andrew T.
Old 16th August 2007, 04:05 PM   #102
panson_hk's Avatar
Hi Andrew,
Yes, I have seen many articles, reports, projects saying shunt is better then series - for Hi-end!
Panson
Old 29th August 2007, 07:24 AM   #103
monkey29's Avatar
Default LME49810 Audio AMP (Samples)
Old 29th August 2007, 07:33 AM   #104
monkey29's Avatar
Default LME49810 Audio AMP (Samples) No2
Old 29th August 2007, 07:36 AM   #105
monkey29's Avatar
Default LME49810 Audio AMP (Samples) No3
Old 29th August 2007, 11:58 AM   #106
CJ900RR is offline CJ900RR  Sweden
Interesting circuit! And I like your design monkey. Nice indeed. What kind of output transistors do you think would be best to use?
Im new on class-a and have some questions on the output stage. How do you increase power. Is it correct as I did in the attached file? (Take no notice on the transistors I only picked a random one.)
Also, how do you callculate output power? I guess it has to do with the MOSFETs or?
Best regards...
Old 29th August 2007, 02:46 PM   #107
panson_hk's Avatar
Best regards...
You may try Leach SuperAmp output topology
http://users.ece.gatech.edu/~mleach/superamp/
Old 29th August 2007, 03:02 PM   #108
megajocke's Avatar
Your distortion plot seems to indicate that it actually already IS current limited.
If we assume it is current limited at 50mA it would be able to provide about 35mA RMS to the load before clipping and high distortion. The 100 ohm load curve shows distortion coming in slightly below 4 volts. 35mA*100R = 3.5V. The 600R load shows clipping setting in at around 20V. 35mA*600R = 21V.
Old 29th August 2007, 03:10 PM   #109
panson_hk's Avatar
Yeah! I would say so based on the data.
Old 1st September 2007, 10:30 AM   #110
veteran is offline veteran  Poland
veteran's Avatar
I can't wait to start assembling this amplifier so I designed my version of PCB and ordered some boards:
Simple audio solutions
blog.unisonus.com
Page generated in 0.12319 seconds (78.05% PHP - 21.95% MySQL) with 11 queries
