Old 3rd June 2007, 06:49 PM   #1
Default "photo" Caps & audio circuits ?
Hi all,
While working on a GC and digging thru my rapidly growing parts, bin I found a couple of caps that are labeled "photo". These are 120mfd @ 330V.
Are these useful in audio circuits?
TIA
7/10
Old 3rd June 2007, 08:18 PM   #2
Photoflash caps are designed for high discharge rates, and I've seen admonishments not to use them for regular cap service. I don't know why not, as they seem to perform the same as a conventional cap of the same value and voltage. Anybody know of a reason to avoid them?
Old 3rd June 2007, 09:40 PM   #3
FastEddy's Avatar
An example: http://www.capacitorindustries.com/web/CD17S.htm ... note that these "photo flash" types are special purpose electrolytic capacitors and may be of only slight value for DIY audio ... but experimentation may be in order.
Old 3rd June 2007, 10:00 PM   #4
Conrad & F-Eddy,
Thanks for the replies...
In an effort to keep moving forward, I've left a terminal strip in the PSU section to facilitate easy CAP experimentation. I will
er-uhhhh ...test them
Onward,
7/10
Old 4th June 2007, 04:50 PM   #5
Seven, what I've heard is that in normal service photoflash caps are charged all the way up, then completely discharged; this once a minute or so, episodically. They are designed and constructed uniquely for this odd sort of service. Put in a power supply, where they are charged most of the way up and then partially discharged and recharged sixty times a second, their service life will be very short.
If you're looking for very good, very economical electrolytic caps, have a look at Panasonic ED, TSHA, TSHB at Digi-Key. I have found nothing better, and I have A-B'd them with the heavy hitters.
Aloha
Poinz
Old 4th June 2007, 05:53 PM   #6
Mahalo P-Dexter,
Seeing your location makes me think I should fly out for a personal A-B test
I'll follow your advice on my next order... I have a handful of chips and a Big trafo, but still need to decide on a project. Hmmmmmm
Aloha
7/10
Old 4th June 2007, 06:00 PM   #7
Juergen Knoop's Avatar
hm, I find the values to small to be useful in a chipamp design
Old 4th June 2007, 06:24 PM   #8
... mine are; 120mfd 350v.
Maybe I'll make a flash
7/10
Old 4th June 2007, 06:36 PM   #9
yes, with 120uF/350V you can't do much exept flashes
Old 4th June 2007, 06:41 PM   #10
Juergen,
How big are you guys using? The original schems I've seen are calling for about 1KuF as the last tank, which looks pretty small to me. 18v into an 8 ohm load is 3 amps, which is going to drain a thousand mic cap pretty quickly.
Aloha,
Poinz
What makes Nichicon "muse"/"for audio" caps different ? percy Parts 2 3rd October 2009 05:53 PM
Mullard: Tube Circuits for Audio Amplifiers" - Price? ray_moth Tubes / Valves 6 21st September 2009 04:52 PM
MIT Open Courseware "Circuits and Electronics" (25 Lecture videos) KP11520 Everything Else 1 2nd August 2007 09:39 PM
"Silver-Carbon" Pot ex Tawan - Photo - & ignore my ugly Pinky! Joe Rasmussen Chip Amps 98 6th May 2007 04:22 PM
Page generated in 0.09138 seconds (79.53% PHP - 20.47% MySQL) with 10 queries
