lm4780 problem lm4780 problem - diyAudio
lm4780 problem
lm4780 problem
Old 3rd June 2007, 02:29 AM   #1
Jim Karr is offline Jim Karr  United States
Default lm4780 problem
I've assembled one of BrianGT's LM4780 boards. Turned on the power, no smoke (praise the Lord). No signal from the speakers, just a very infinitesimally small hum. Apparently it's in protection of some sort.
I don't know what voltages and other measurements I should be getting on each pin out. Anyone have any ideas?
No solder bridges, and I've checked my connections several times. It all looks correct. Help?
As for me and my household, we shall serve the Lord. Joshua
Old 3rd June 2007, 06:32 AM   #2
YFW is offline YFW  United States
Account Disabled
Please check the output DC voltage which should be very low if everything is in normal condition.
Old 3rd June 2007, 01:22 PM   #3
jackinnj is offline jackinnj  United States
jackinnj's Avatar
lm4780 problem
Default Re: lm4780 problem
How have you connected the MUTE pin?
Old 8th June 2007, 10:18 PM   #4
DC voltage is almost nonexistent. It's been so long since I worked on this amp I don't remember the exact value, but I do remember that it was miniscule.
I believe the mute pin is just fed through the board into a plain unclad hole, so it is not connected at all.
Thanks for your responses!
Old 9th June 2007, 12:38 AM   #5
jackinnj's Avatar
lm4780 problem
Well, ther you go...the mute of the LM4780 needs a few milliamps to turn the amplifier on...see the product PDF.
Old 11th June 2007, 11:14 AM   #6
sangram is offline sangram  India
On that particular board (at least the Peter Daniel version) there are two pads that look like surface mount pads on the 'copper' side of the board, where I solderded the mute resistor. It's not marked on the silkscreen, so it's easy to miss.
Old 13th June 2007, 08:56 AM   #7
zei is offline zei  Sweden
I did the same mistake
ie, i did not solder the MUTE resistor and i got no sound.
So follow sangram,s suggestion and you will have music in no time
/Z
Tala är tiga, silver är guld
lm4780 problemHide this!Advertise here!
Problem with LM4780 Cyberzim Chip Amps 14 24th January 2010 05:40 PM
LM4780 problem - need Help AndriyOL Chip Amps 56 29th January 2009 07:58 PM
LM4780 problem Lamicz Chip Amps 6 6th November 2005 01:50 AM
LM4780 problem Faber Chip Amps 8 16th August 2004 04:39 PM
Copyright ©1999-2017 diyAudio
