| Chip Amps Amplifiers based on integrated circuits |
While in the process of building a suitable enclosure for my first gainclone, I started picking up parts for number 2... this may get ugly
![]() Anyway, I bought a 48VCT(24+24)/ 500VA tranny, carried it home and powered it up. I put a rectifier across one secondary and the center tap(potted type) and grabbed my meter expecting to see approx- 33-34 VDC . Instead I get a reading of 23V. I then did a quick search of this forum and saw in a post that I should load the output with a resistor (10K suggested). I did this... still 23V. Am I missing something? 7/10 |
#2 |
diyAudio Moderator Emeritus
Is your meter set to DC voltage? Since you have a center tapped transformer you want to measure the voltage between the center tap (ground) and each rail after the rectifier.
Brian |
#3 |
Thank you for the reply...
Yes, my meter is set to DC. ![]() Currently with a 10K resistor across the rectifier +/- connections I get a 23VDC reading (at +/- of rectifier). Set to AC and measuring either sec to center tap, I get 26.4 VAC.... 53.4 VAC from Sec to Sec. I keep reading that your DC voltage should be 1.41 (?) times the rated VAC, but both of my PSU setups measure a DC voltage roughly equiv to the rated AC output of the XFMR. My wavetek and my fluke concur...mostly Thanks 7/10 EDIT* to add; I grabbed my el-cheapo analog meter and it too agrees... 23VDC |
#4 |
so whats the voltage of just the secondaries on the tran.? Maybe u are getting 1.41 times as much voltage, you just haven't realized it yet. Maybe then again not and your problem lies else where.
#5 |
Try your rectifier across the full secondary ... your primary may be 220 VAC input and the secondary output is relative to that ...
Over compression is a problem with modern CD recordings |
#6 |
seventenths,
You are getting the correct answer for your test setup. I am assuming your rectifier is a bridge so the waveform is a fullwave rectified sinewave. The peak voltage is Vrms*1.414-2*Vd = 26.4V*1.414-1.2V = 36.1V The Meter on DC will measure the average DC voltage. Vavg = Vpk*2/Pi = 36.5*2/3.1416 = 23.0V Close enough? If you want to see what you were looking for you need to add a filter capacitor across the bridge output. I hope this is helpful. VSR PS: my original post only assumed one diode. By using two at Vd=0.6V the answer comes out to almost exactly 23.0V |
#7 |
Do you have some filter caps in place?? If not the DC range on the meter will read funny (as it tries to average the pulsating DC out of the diodes).
#8 |
sherelec / hugemon: right, right, right ... you have to add some capacitance to the rectifiers to get the peak (stored) DC voltage reading ...
#9 |
Only a whole bunch That is exactly what I needed. Thank you all for taking the time to respond. Onward... oh whats that smell... could it be the sizzling 35V cap? Oh yeah some DA got in a rush and didn't reconfigure to the center tap after testing sec-sec7/10 |
#10 | |
Brian |
| newbie with input tran. question and wiring question | imo | Solid State | 0 | 18th January 2006 10:10 PM |
| Capacitor Question /question on cap | TunaFish | Tubes / Valves | 14 | 12th January 2004 02:23 AM |
| PS question - tformer question actually | breguetphile | Chip Amps | 2 | 30th May 2003 01:29 PM |
| old speaker question, bullet midrange question & link to speaker project | wallijonn | Multi-Way | 10 | 5th November 2002 06:03 AM |
| Page generated in 0.09938 seconds (79.74% PHP - 20.26% MySQL) with 10 queries |
