NE5532 or OPA2134
NE5532 or OPA2134
Old 1st June 2007, 09:22 AM   #11
YFW is offline YFW  United States
Account Disabled
Default consider the spec.
I suggest you should condider the requirement of the circuit first.
NE5532 could work in higher supply voltage,for example,+/- 22V.
But OPA2134 could only work under +/-18V.
If you wanna change the OP,try to confirm the working voltage in advance.
Old 1st June 2007, 01:20 PM   #12
ctong is offline ctong  United States
Default Re: consider the spec.
In most cases the supply voltage is below +-15V. I actually have not seen one going above +-18V. And I am not sure what benefit a designer gets out of a +-22V supply.
CT
Old 1st June 2007, 04:07 PM   #13
Account Disabled
Default Re: Re: consider the spec.
Some designers will increase the power supply voltage achieve higher dynamic range,although the signal output is tiny.
For a dual OP like NE5532 working in high voltage,maybe you could try OPA2604 which could work under +/-25V.
Old 1st June 2007, 04:22 PM   #14
Default Re: Re: Re: consider the spec.
Any particular component/model that uses such a high-voltage supply?
CT
Old 1st June 2007, 05:05 PM   #15
gootee is offline gootee  United States
There might be lots of different reasons to use any particular supply voltages. Needing a larger output swing might be a common reason for using higher supply voltages.
One case might be when a device has better specs at +/-22V, for a particular application. For example, if you look at the OP275 datasheet, at http://www.analog.com , Figure 5 in the Applications section shows that in order to drive 10V RMS into 600 Ohms and still get low THD (Total Harmonic Distortion), the supply voltages must be >= +/-19V. For 1 kHz 10VRMS into 600 Ohms, with +/-18.5V supplies, the THD is about 0.1%. But with +/-19V supplies, the THD is about 0.001%, and decreases further as the supply voltages approach +/-22V.
- Tom Gootee
http://www.fullnet.com/~tomg/index.html
Old 1st June 2007, 05:37 PM   #16
The original posting of this thread concerns the use of opamps in a CD player. My comment is in this context. I have not seen any player using a supply voltage higher than +-18V. There also is no need for a 10V rms output.
CT
Old 1st June 2007, 05:46 PM   #17
Account Disabled
My suggestion is,if you wanna change the OP,confirm the working voltage first,because this will have possiblity to hurt the OP.
Old 1st June 2007, 06:11 PM   #18
Default Re: NE5532 or OPA2134
Originally posted by wandelblu
Hi!
I have a cd player SONY XA2-ES, It has four opamp NE5532, I'm thinking to change them with OPA2134.
Is it really a good sound improvement?
Can you give me some advices?
Best Regards.
Enzo
I am contemplating opa627s for my scd-c555es. But I need to use adapters and perhaps the soic packaging, which requires soldering SMT components, not a pleasant task. I will post my findings.
CT
Old 9th June 2007, 12:53 PM   #19
linjunan is offline linjunan  Taiwan
I have ever changed my SONY XE600(A very cheap SACD Player and only sold in Japan & Taiwan.) from NJM4565M to OPA2132AU.
It sounds more wide and good in high frequency, but it losts the feeling of Sony; I mean it does not sound like Sony style.
At finally, I use OPA2111. It sounds very suitable for me. But, I think Sony style audio is very special. I will change OPA2111 to 4565 if I can get 4565.
NE5532 or OPA2134Hide this!Advertise here!
Upgrade for NE5532 diy student Parts 78 15th January 2018 01:12 AM
What about NE5532? rhavecilla Chip Amps 12 6th September 2007 03:05 PM
PGA2310 & NE5532 get hot? sergiusz Digital Source 10 20th December 2005 12:32 PM
Ne5532 zahlm Parts 3 13th May 2004 09:22 PM
Suspicious NE5532 wxn Parts 22 13th February 2004 08:48 PM
