LM4780 Kit and Transformer Selection
Old 31st May 2007, 12:54 AM   #11
seventenths is offline seventenths  United States
The spreadsheet is available on the National Semi website...
7/10
Old 31st May 2007, 12:58 PM   #12
bacworth is offline bacworth
Send a message via MSN to bacworth
that is correct
Old 31st May 2007, 01:59 PM   #13
R.I.P.
Hi Backworth,
what's the problem with the spreadsheet?
I can see 4r0 load and 59W @ 1% distortion from +-25.4Vdc.
The orange cell showing 1.04C/W indicates the chip is needing a lot of sink to stay cool.
The N/A in the cell directly below tells you the thermal resistance of the isolated package cannot get rid of the heat in the chip.
Am I correct in interpreting assumption4 that the chip is fixed with thermally conductive compound direct to the sink? What voltage is the sink at?
Add in the reactance of a real speaker and the chip is starting to run into real stress. Drop the impedance to 4ohm and 60degree phase angle for a severe speaker load and the chip will start cutting out if you try to get maximum power out of it on a PA type duty.
Use it for typical domestic duty where average output is below -20db ref maximum output (ie. 0.6W average =600mW)and the chip will stay cool enough.
This will require mid efficiency speakers, try 88db/W to 92db/W.
Use this amp to drive an 84db sub-bass and it will tell you it does not like it.
All that comes from reading between the lines in the datasheet and that orange cell in the spread sheet.
I get criticised for reminding folk that chipamps do not like low impedance loads. Who wants to put the alternative case today?
If you parallel two chips so that each thinks it is driving an 8r load then the heat problem virtually goes away. You still get 60W into the 4ohm load from the parallel pair, but at far less distortion.
Try changing load to 8r and then look at the parallel output.
regards Andrew T.
Old 31st May 2007, 03:20 PM   #14
R.I.P.
having downloaded that spreadsheet, I tried a few numbers.
Keeping the same 4r load, +-25.4Vdc & 25degC ambient.
I had a look at the graph of power dissipation (per double chip) when output averages -10db ref maximum. Pd=47W @ 6W+6W output.
That 1.04C/W sink will run at about 25+49=74degC.
Using Rth c-s of 0.5C/W, the case temperature will be near 100degC when the output averages 6W into 4ohms. I would suggest a sink with Rth s-a of about double the heat dissipation of the figure quoted in the spreadsheet.
6W is loud into 90db/W speaker, but may be the sort of level that might be attempted during a party (if the neighbours don't complain).
regards Andrew T.
Old 3rd June 2011, 12:31 AM   #15
w0l is offline w0l
Does anybody still have this spreadsheet?
Ian
Old 3rd June 2011, 02:19 AM   #16
Redshift187 is offline Redshift187  Canada
overture design guide - Google Search
Tyler
Old 3rd June 2011, 02:26 AM   #17
w0l is offline w0l
Default Thanks
Thanks!!
Should have searched for guide rather than spreadsheet!
LM4780 Kit and Transformer SelectionHide this!Advertise here!
Advice for transformer selection. beppe61 Power Supplies 20 2nd August 2007 11:37 AM
Transformer selection question Trout Tubes / Valves 39 11th December 2005 02:23 AM
Transformer Selection Audiofng Solid State 9 7th December 2002 08:12 PM
Transformer selection for DIY Electrostatics phishead8 Multi-Way 5 15th May 2002 07:09 AM
