diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Chip Amps (http://www.diyaudio.com/forums/chip-amps/)
-   -   Need some help: one vs. two rectifier boards? (http://www.diyaudio.com/forums/chip-amps/102257-need-some-help-one-vs-two-rectifier-boards.html)
ebenai 21st May 2007 01:35 PM
I'm assembling Peter Daniel's LM4780 kit. It comes with two rectifier boards, but I only have one transformer. I read a post in which only one board was used for the LM 3875. Can I use only one? The only way I could do it would be to connect two wires to each one of the V+, PG+, V-, PG-. The LM3875 rectifier has 2 connections for each one. The LM4780 has only one. Appreciate some advice.
DeanP 22nd May 2007 06:48 PM
Use only one power board as you'll end up getting a ground feed loop.(name?) I tried two power boards with one tranny and I get the buzzing. I'm in the middle of rebuilding and plan on using only one power board per tranny.
There is a thread here on just this and what was done to get rid on the buzzing.
edit: here is the thread http://www.diyaudio.com/forums/showt...threadid=98928
lgreen 22nd May 2007 07:15 PM
one is fine
Use just one rectifier board. It worked for me.
ebenai 22nd May 2007 09:32 PM
Thank you very much guys. Will do.
ianpengelly 25th May 2007 12:49 PM
This is worth a read:
http://www.diyaudio.com/forums/showt...threadid=95451
I have now moved to two transformers, which you can do at a later date as a upgrade.
Good luck.
Copyright 1999-2017 diyAudio
