| Chip Amps Amplifiers based on integrated circuits |
I built my first amp, a BrianGT Stereo. Avel 250VA 25 dual P & S.
Before I read the manual, I installed a 250K dual, cheap pot for a volume control, (I could not get any PEC samples). . I found if I turn the pot to zero ohms (full volume), and use my walkman as a preamp the sound is better than anything I have heard in a long time. I am worried about the heatsink temperature, it seems too warm. I bought my heatsink from BOSS on ebay, (I discovered him searching in this forum). 10mm plate big fins, 5 3/4" X 3". I am wondering if I goofed the star ground. I searched here a long time, I will post pictures when I find a camera. No hum, sounds good to me, Please explain the ground star. AC and DC, are they tied together? 35VDC on each rail, no DC at outputs. Thank You............... |
#2 |
You omitted to say if you are driveing 8 ohm loads or trying to kill something with 4 ohms. As you are not mentioning smoke I assume you have an 8R load.
Is it getting hot with no signal? If so it may be oscillating What is your concept of hot... how long can you keep your finger on it? If you have no hum, you don't have to worry about the ground further I think.. ground star is used to give multiple parts of the circuit refference to the same ground point.... You will still go through a couple of stages in all likelyhood of understanding the subtleties of layout VS schematic design... I know I am still learning... If it sounds good, its time to congratulate yourself... 250k pot is probaly way to big, and yes I think almost anything is better than a cheap pot...a source with its own volume control is ideal as the amp in all likelyhood sees a fixed impendance. |
#3 | |
100 F after 3 songs |
#4 |
Electrons are yellow and more is better!
100 deg F (38 deg C) is nothing, perfectly safe but you may check how hot the IC is. 10-15 deg C more is OK. Less is better of course.
/Per-Anders (my first name) or P-A as my friends call me |
#5 |
Dead on, don't think anything is wrong with it...
You will still learn the finger thermometer... pretty accurate for these kind of things... |
#6 |
Thank you All
#7 | |
I don't understand this. How have you wired the pot?
regards Andrew T. |
#8 |
my guess would be zero ohms between the wiper and the end of the track that's connected to the input.
#9 | |
I removed the pot 250K too much, I will replace it with something else. Pot worked, not much adjustment... |
#10 |
Hi PPC,
did you wire up the pot as a variable series resistor or as a volume control? Please tell us how you wired it up.
regards Andrew T. |
| punch 60 dsm getting warm | ben04srt | Car Audio | 5 | 3rd June 2009 10:37 PM |
| saa7220 gets warm?? | jnewbold | Digital Source | 13 | 28th October 2008 09:11 AM |
| SI T-amp warm-up? | irss | Class D | 3 | 8th April 2005 11:40 PM |
| My amp gets warm... | Jye | Multi-Way | 6 | 21st November 2003 11:53 PM |
| Page generated in 0.11518 seconds (82.85% PHP - 17.15% MySQL) with 10 queries |
