no spike protection allowed
Old 11th May 2007, 04:58 PM   #1
tryonziess is offline tryonziess  United States
Default no spike protection allowed
is there a good quality high powered chip amp without internal spike protection which i could use in a 250 watt output project.
Old 11th May 2007, 05:29 PM   #2
drummer_Dave is offline drummer_Dave  Canada
I'm not trying to be rude or anything, but what is your reasoning for not wanting spike protection? you could use several lm3886 or lm4780 in bridge and or series configurations to get up to your power requirements, but they still have spike protection. I am very interested to find out what you are planning here.
here's a link to a very nice project
http://www.diyaudio.com/forums/showt...threadid=90864
good luck
Old 11th May 2007, 06:47 PM   #3
jackinnj is offline jackinnj  United States
jackinnj's Avatar
OPA549 from Texas Instruments -- bridge two of these -- note that most chipamps have some kind of current protection -- amplifier chips want good heatsinking.
you could also use an LM4702 and parallel some HexFETs -- but you need to get the bias up to a couple of volts (or use Lateral MOSFETs) -- somewhere I posted a schematic from an article that Borbely wrote up for audio amateur.
Old 11th May 2007, 07:07 PM   #4
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
BWRX's Avatar
It has potential to be a nice project. There were a lot of problems with the first design posted by DJexprice.
Brian
Old 12th May 2007, 09:24 PM   #5
Default why no spike
i have noticed fluctuations on the scope when certain low frequency music is playing are similar to the fluctuations when the 3886 is clipping. i just wanted to rule out the possibility that spike might be coming on when it is not needed to protect the chip. i do not know enough about this subject to explain this phenomenon other than trial and error. substituting and observing are my best methods at this time
Old 13th May 2007, 01:33 PM   #6
jackinnj's Avatar
Default Re: why no spike
What was the thermal impedance of the heat sink you were using? (or can you give us an idea of its approximate surface area).
Old 13th May 2007, 05:52 PM   #7
the area of copper was 5x12 inches 1/2 inch thick with 11 5x1 fins. the sink temperature never reached 100 f. the only fluctuations occured at roughly 80hz and below into a 12 inch woofer. actual volume was quite "loud". no more specifics since i would not no what to look for. i am only following a hunch that spike might be a little hasty in its activation. it could be something else, but i have good clean response until these parameters come together. this is a new endeavor and i am learning as i go.
no spike protection allowedHide this!Advertise here!
OPT Voltage spike protection with zeners bigwill Tubes / Valves 8 17th July 2009 04:24 AM
How much ripple on B+ is allowed? Rundmaus Tubes / Valves 11 16th October 2005 02:19 AM
Anyone use these Spike Feet? m1abrams Multi-Way 2 22nd July 2004 06:54 PM
Blackgate Super-E configuration! Polarized cap allowed? w00t Chip Amps 1 20th June 2004 07:40 AM
How much DC offset allowed in headphone amp? jwb Headphone Systems 2 5th August 2003 11:15 AM
Copyright ©1999-2017 diyAudio
