Old 11th May 2007, 12:53 AM   #1
ppcblaster's Avatar
Default BrianGT Amp board, Rz, Cz
BrianGT Amp board, Rz2.7 2 w, Cz 0.1 cap
What are these doing in the Stereo amp circuit?
I searched, no luck.
Thank You
Old 11th May 2007, 05:26 AM   #2
scottw is offline scottw  United States
Z for zobel. These are optional but may prevent the chip going into oscillation if the speakers are a tough load. I guess you missed the Zobel Wars of 2004.
http://www.diyaudio.com/forums/showt...?postid=452840
Scott
"The Adobe Updater must update itself before it can check for updates. Would you like to update the Adobe Updater now?"
-Adobe Updater
Old 11th May 2007, 10:32 AM   #3
ppcblaster's Avatar
Default BrianGT Stereo Amp board
Thank You for the Z info..
At the input is R1 a 1K r, then R2 22K ohm goes to ground.
What is R2 22K ohm doing in the circuit?
R1 is explained in the LM3883 datasheet.
Thank You
Old 11th May 2007, 04:15 PM   #4
R2 (22k) is providing the input impedance for the amp.
Scott
-Adobe Updater
Old 11th May 2007, 04:21 PM   #5
ppcblaster's Avatar
Default R22
Is that why a 25K volume pot is recommended?
I used a 250K dual pot. (all I had), Should I make some changes?
Thank You.
Sure Electronics New Tripath Board 4*100W class-D Amplifier Board 7788q Class D 312 18th May 2012 01:32 AM
My Cambridge 500SE, needs an output board (to replace internal DAC Board) slbender Digital Source 0 15th May 2008 01:36 AM
BrianGT Amp Board R2 help ppcblaster Chip Amps 0 11th May 2007 01:28 PM
BrianGT's LM3886 board, and hiss Russ White Chip Amps 9 20th March 2005 08:10 PM
BrianGT Aleph board Question, C7 and C9 wchick Pass Labs 2 21st May 2003 11:13 PM
Page generated in 0.06631 seconds (74.06% PHP - 25.94% MySQL) with 10 queries
