Old 10th May 2007, 06:48 AM   #1
NIC1138 is offline NIC1138  Brazil
Send a message via ICQ to NIC1138 Send a message via MSN to NIC1138
Default TDA2050 success story
Hi. Just tought it might be interesting to post about a TDA2050 amp I just built.
I still have to test it to know exactly how well it is working, but I was already able to listen to Discharge and nag my neighbours... I'm sending the eagle lay-out, but I used it only for drilling / punching the holes. I drew the board by hand, and the power tracks are about 5mm thick.
I used a 1A +-15V power source, and a feeble oval speaker savaged from a computer "multimedia" amp. Pictures coming soon!...
Old 16th May 2007, 04:46 AM   #2
Finally I got my camera back... Here are some (ugly!) pics of the amp.
The design is basically the one suggested on the datasheet. I just redraw to remove thas space for the stuff that you might use on the TDA2030.
Caps are 16v... I also changed the type of the input capacitor because it makes me nervous to use electrolytics there
Yes, I decided to drill the holes after, and then decided I did need them!
Old 16th May 2007, 04:48 AM   #3
Default backside
Old 16th May 2007, 08:38 PM   #4
Nordic is offline Nordic  South Africa
Nordic's Avatar
thanks for the share....
Care to post a picture of the punch....? I keep hearing about them... drilling is such a pain...
Old 17th May 2007, 01:14 AM   #5
My pleasure!... I created a thread just for this.
PCB perfurator thread
Old 17th May 2007, 02:12 PM   #6
"Smoke test" of the PSU. Some serious 2.46 ampères going on! Almost 10W on "big green" 1.5 ohms load. The heatsink is too small for that... The voltage on the regulator input is 20V, with a 5V output so it means 15*2.46 = around 37W It was almost too hot for touch (probably would be with both regulators on!)
Old 22nd May 2007, 01:17 AM   #7
Finished, in the case. I'm thinking about installing a fan somewhere, since it's getting too hot!... The boards are fixed with 10mm screws, glued with super bonder.
Fun with glow tubes, a success story zigzagflux Tubes / Valves 0 11th May 2009 09:40 PM
Tda2050 Jpoole908 Vendor's Bazaar 0 1st June 2008 06:34 PM
Tda2050 Mr. Triatic Solid State 8 26th April 2004 06:00 PM
Page generated in 0.08610 seconds (75.53% PHP - 24.47% MySQL) with 11 queries
