Old 9th May 2007, 02:49 AM   #1
Default Ground LM3886 chipamps
Hello,
I was wondering when grounding the LM3886 amps, is it better to use one wire run from each amp to star ground or what I want to do is use one long wire to span all amp chips and then "T" into the long wire from each amp and then connect that long wire to star ground? It seems it would just save from trying 4 wires, in my case, to star ground. Doing the latter I would only need to do 2 wires. Btw I'm doing 3 monoblocks in one chassis and all with their own PSU and tranny.
Thanks,
Chevy
Old 9th May 2007, 06:34 AM   #2
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Default Re: Ground LM3886 chipamps
Originally posted by chevy2410
Hello,
Thanks,
Chevy
If you do the T stuff, you no longer have star ground. That means, that earth currents from one chip set up error voltages across the parts of the T wiring. That means that not all chip earths are at earth, but that some float on error voltages above ground. That means that this error voltage ends up as input to the chip. You don't want that, I guess.
Once you understand the reason for star ground, you would no longer entertain this type of ideas
If you draw it out, with currents shown, and show voltages in the wire impedances resulting from these currents, it will be much clearer.
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 9th May 2007, 08:39 PM   #3
Jan Didden
Ok, I won't do the "T" stuff. I will run separate wire from each chip right to star ground.
Thanks,
Chevy
why bass is tight and controlled on SS than chipamps like lm3886? rhythmdiy Solid State 46 14th December 2008 01:32 PM
LM3886 Amp Oscillating When Ground Loop Isolators Are Used (?) MartyM Chip Amps 8 30th August 2008 09:05 PM
Parallel LM3886, input ground, power ground, safety resistor and oscillations. markiemrboo Chip Amps 5 9th August 2007 03:50 PM
LM3886 tri-amp pcb ground question m@ Chip Amps 8 28th June 2005 09:26 AM
LM3886 p2p - ground issue Stabist Chip Amps 0 20th January 2005 02:03 AM
Page generated in 0.08322 seconds (76.07% PHP - 23.93% MySQL) with 10 queries
