Old 8th May 2007, 01:25 PM   #1
Dxvideo is offline Dxvideo  Turkey
Dxvideo's Avatar
Send a message via Yahoo to Dxvideo
Default ALPS RK168 pot pinout????
Hi all,
I have a pair of ALPS RK168 type motorised potentiometer. Theyre dual gang and 10Kx2.
However I cannot find the pins functions.. Does anybody knows the pinout of that pots?
Thanks in advance.
Best regards,
Ozgur
Old 8th May 2007, 02:23 PM   #2
Sonusthree's Avatar
Default Re: ALPS RK168 pot pinout????
Originally posted by Dxvideo
Hi all,
Thanks in advance.
Do you have a multimeter to test for yourself?
Usually the middle pin (2) is the 'wiper' and the resistance between the 'wiper' and the other pins will change when you turn the pot.
Usually pins 1 and 3 are fixed at 10KOhm.
Obviously you will have two extra pins that power the motor.
All of my Alps pots are wired the same but this one has two extra 'Dummy' pins. (not in use.)
Alps website
Datasheet
I found all of this information with Google "Alps Japan".
Old 8th May 2007, 02:39 PM   #3
Dxvideo's Avatar
However this pot has 8 pins. And there is no middle point.
And there is no data in datasheet..
Best regards,
Ozgur
Old 8th May 2007, 03:31 PM   #4
Sonusthree's Avatar
Please look again!!
The picture (and datasheet) clearly shows the pin numbers.
Two of those pins are not connected (labelled 'Dummy').
THE TWO OUTSIDE PINS ARE NOT USED and the others are numbered on the picture.
The +ve & -ve are also clearly shown for the motor control
Usually, Pins '2' are the wipers.
Usually, pins 1 and 3 are fixed at 10KOhm.
You can check this with a resistance meter.
Martin.
Martin
Old 8th May 2007, 03:42 PM   #5
Sonusthree's Avatar
This may explain better
Martin
Old 9th May 2007, 07:27 AM   #6
Dxvideo's Avatar
Thank you friend.
Now I understand! And I can mesaure now.
Best regards,
Ozgur
Old 29th December 2011, 11:11 AM   #7
Hi, I need to replace an old Soundwell 20K pot with an ALPS RK16812MG LOG 10 KDx2.
As far as I understand, in order to mentain the same value I need to add 10K 0.25W series resistors. My question is ( dooh ) which pins should I use to connect the 10K resistors ?
thanks
Old 29th December 2011, 02:22 PM   #8
LE: input pin - solved.
Does anyone know the pinout of AES/EBU on XLR ? Johnix Digital Source 1 15th July 2008 05:19 PM
Different pinout for the same BJT alfaudio Solid State 3 29th June 2007 03:27 PM
Alps RK168 pots in Eagle? Nisbeth Parts 2 27th March 2005 11:08 PM
7-pin DIN connector pinout? Mr Evil Everything Else 0 25th November 2004 03:21 PM
help with pinout karma Tubes / Valves 15 14th May 2003 11:05 PM
Page generated in 0.09314 seconds (77.89% PHP - 22.11% MySQL) with 11 queries
