| Chip Amps Amplifiers based on integrated circuits |
I am new to this design so I need some help. I am a luthier/music enjoyer and I need to kill 2 birds with one amp. I am going to make 3 gainclone amps and 3 speaker systems.2 for normal stereo and one for a subwoofer. The sub woofer system will also be a bass amp for testing the electronics in my bass guitars and effects pedals. Hence the need for clean sound. So first question should I design a active or passive filter for the "music enjoyment" sub woofer amp so as to get some good bottom end from my CD's? If so can you direct me to some circuits. How do I bridge left and right channels to get the input. I am a bit limited on electronic theory so I build guitars to make up for that.
Thanks, Rob Currently listening to: El Danse de Moises by Roberto Rodriguez |
#2 | ||
You seem to say you are a bit of an electronics noob, but it isn't necessarily that difficult if you get good instructions, etc. One place you definitely do get that is ESP if you buy one of the pcb's for his projects. He specifically asks that people link to the front end of his website rather than individual projects but just follow the links to the projects pages. There's an excellent 4th order linkwitz/riley crossover, I've built one myself and it's great and not really difficult. He also has other related stuff; a +/-15v power supply for opamp based projects like pre-amps, crossover, etc, equalisers, power amps and all kinds of stuff. He also has articles which are really informative. There are two on bi-amping (use of active crossovers), one on active verses passive crossovers and lots of other relevant stuff. When you are designing a passive for a sub, and therefore the crossover frequency is very low, the large value inductors necessary are the biggest problem. you usually have to go for ferrite cored rather than air cored inductor coil and then you introduce distortion and high series resistance (which means significant power loss). Quote:
Bridging generally refers to using two amps to drive one speaker driver and get nearly 4 times the power of one of the two amps.
"There's no greater sign of genius than the scorn of fools" -Albert Einstein. |
| 4x12 Guitar cab using guitar and bass speakers help | andrewskaterrr | Instruments and Amps | 15 | 23rd April 2009 11:43 PM |
| DIY Guitar/Bass/Anything amp! | Christovftw | Solid State | 0 | 7th February 2009 08:26 PM |
| any electric bass players? im building a bass guitar cab | KOA | Instruments and Amps | 27 | 30th April 2007 03:49 PM |
| Guitar amp as bass amp? | silentblackhat | Instruments and Amps | 10 | 13th March 2006 05:06 PM |
| bass guitar cab | random_id | Multi-Way | 6 | 22nd July 2004 11:30 PM |
| Page generated in 0.08927 seconds (75.23% PHP - 24.77% MySQL) with 10 queries |
