| Chip Amps Amplifiers based on integrated circuits |
I'm looking to build a new regulated PSU since I was so impressed with Carlosfm's LM338 design, the best thing I've heard since bypassing the preamp...
But it looks like he has been snubbed, too bad. Does anyone have a newer competing design or is Carlos' still the reference? |
#2 |
diyAudio Moderator Emeritus
There are lots of ways to make a regulated supply. Have a look through the power supply forum. Carlosfm's design really wasn't anything special.
Brian |
#3 |
Try different chips instead of the LM338.
#4 |
try LT10** series chip.
#5 |
Lol: LM7*xx
*= 8 for +, 9 for -. XX= 05 through 24 in certain increments. ![]() PS: This is an OLD regulator though, so you probably have heard of it. |
#6 |
Why do you need a competing design? If you like the result, use it. There really isn't anything to want beyond it, the noise level is sufficiently low to work well with typical chipamp chips and it is a basic, inexpensive and easy to build circuit. Is it TOO easy, you want a challenge? I suppose you could put a capacitance multiplier in front of it and add pass transistors for higher current, or sort of incorporate the two into the same stage.
| G&S Designs | fongman | Car Audio | 13 | 25th March 2010 04:33 AM |
| Regulated or non-regulated SMPS | longitude | Class D | 5 | 8th May 2007 03:02 PM |
| QSC designs | clovi_kate | Solid State | 1 | 22nd March 2007 09:49 AM |
| Any PHY-HP KM 30 SAG DIY designs? | j.burtt | Multi-Way | 2 | 25th November 2006 08:08 PM |
| Page generated in 0.07606 seconds (75.67% PHP - 24.33% MySQL) with 10 queries |
