| Chip Amps Amplifiers based on integrated circuits |
Does anyone know how to get rid of boom when I turn on my amp? BTW this boom is not heard when the signal cable is not in the amp.
TNX |
#2 | |
Data sheet of TDA1557 says:
You need to check mute/standby configuration. |
#3 |
Does anyone have a circuit which works with no on/off plop?
#4 |
This phenomenon is generally caused from wrong grounding problems and DC offsets on output.
For example I had three TDA1514A amplifiers. In the datasheet they write "no switch on / off clicks" however I had. Then I desoldered all components then matched all resistors and make a good start grounding. After a full hour works it worked perfectly and no switch on/off plops. Another example; I have a discrete amplifier and it has exactly no switch on or off plop blocking circuit, but I cannot hear any plop on switching.
Best regards, Ozgur |
#5 |
For example I had three TDA1514A amplifiers. In the datasheet they write "no switch on / off clicks" however I had. Then I desoldered all components then matched all resistors and make a good star grounding. After a full hour works it worked perfectly and no switch on/off plops. Another example; I have a discrete amplifier and it has exactly no switch on or off plop blocking circuit, but I cannot hear any plop on switching.
| Tda1557q | mravlcax | Chip Amps | 6 | 7th May 2012 06:06 PM |
| PCB layout for TDA1557Q | syber | Chip Amps | 4 | 13th December 2011 04:45 PM |
| Will start my new Gainclone from Start, Need Help | samsagaz | Chip Amps | 4 | 27th May 2008 09:39 AM |
| where to start? | elementx | Digital Source | 3 | 19th December 2006 09:34 AM |
| Don't know where to start. | Venom908 | Car Audio | 2 | 14th December 2006 02:12 AM |
| Page generated in 0.08123 seconds (74.29% PHP - 25.71% MySQL) with 10 queries |
