Old 2nd May 2007, 03:55 PM   #1
chuck55 is offline chuck55  United States
Default Gainclone with battery vs. A/C power
Are there any benefits in a 3875 G-C to go with battery power instead of the A/C from the wall?
How many 12VDC batteries do I need?
Old 2nd May 2007, 04:23 PM   #2
what is your proposed load?
What is your target power output? Maximum and average?
regards Andrew T.
Old 3rd May 2007, 12:59 AM   #3
! is offline !  United States
No, use batteries only if you need it portable. A general comparison to what most people use for AC-DC would entail about 4 x 12V batteries (as 24-0-24) of over a dozen amps each else you could only listen for a short time before wearing down the plates and having the continual burden of frequent recharging (and added cost of the charger).
Old 3rd May 2007, 05:51 PM   #4
I don't have a scope to measure power consumption. The speakers are 3 & 4" single driver 80-88dB efficient with 8 ohm load.
The 88 dB runs fine on my 22wpc Denon minisystem. Volume is set to 20 out of 34 max.
Old 3rd May 2007, 06:55 PM   #5
When I wrote a dozen amps each above I'd mistyped, meant Ah, amper hours battery capacity.
Old 3rd May 2007, 11:54 PM   #6
if 88db/W and 22W get on as partners then 80 db/W will need 160W or thereabouts to match the volume.
Both these are beyond what would be sensible for battery powered.
1 or 2W and 96db/W would better suit battery power and only if set up to require very low quiescent current.
regards Andrew T.
Definitive 24V Gainclone Battery Supply Recharging? mgreene Chip Amps 21 13th January 2009 02:03 PM
Battery powered gainclone grounding? abkingsbury Chip Amps 0 10th August 2004 04:51 AM
How much power will a battery powered GainClone produce? Tony D. Chip Amps 2 5th July 2004 09:20 PM
Battery Gainclone? chrille Chip Amps 17 13th October 2003 08:00 AM
Page generated in 0.07830 seconds (73.73% PHP - 26.27% MySQL) with 10 queries
