would CDR file be helpful, or should I export it as ps or eps?
single layer pcb, worked great for me , two vias, MKT capacitors used, two electrolythic..from orginal aplication and test circuit foud in datasheet.
depending of overall application (mean amplifier, preamplifier, device..) ground loop problem could appear, but quick and dirty solution worked for me: two little transformators (closely 1:1) found in old modem pci cards connected on left and right input (if you do stereo) do the job.
btw, all my pcb I do manualy..that's bit crazy isn't it, but it is the only way to actualy do the pcb as you realy want to
regards
regards
