Old 25th April 2007, 11:32 PM   #1
Send a message via MSN to youyoung21147
Question TDA7294 bootstrap and svr pins
Hello,
I have bought some TDA7294 chip amps and found two strange pins on them : the boostrap and svr pins.
I've read the datasheet of this component but I didn't understand the purpose of these two pins. Maybe I've read bad, or it isn't clearly explained... If I'm right, they don't exist on ICs like LM3886 and LM4780, which I have already played with in the past.
Can I leave them floating ? What is their precise purpose ?
My application is to power a tweeter in an active setup, and cables will be no longer than 2.5 meters.
TDA7294 datasheet
Fostex F120A speaker pair for sale - 250€ only !
Old 26th April 2007, 11:38 AM   #2
space is offline space  Norway
If you did look at the first page (fiure 1) of the datasheet you will see that the bootstrap pin is connected to the output via a polarized cap, and SVR (pin 4) is shall be connected to earth.
Here is an updated datasheet for the TDA7294
space
Old 26th April 2007, 12:28 PM   #3
Thanks for the updated datasheet !
I've understood the purpose of SVR : it seems to serve as signal reference when in mute mode, so should be grounded.
But I don't understand the role of the bootstrap pin.
I know they propose to place a 22µF cap between this pin and out, but it doesn't explain me what is the function on this pin.
Can I leave it floating ? Or replace the cap by a wire ? They say a smaller value degrades signal at LF, I assume it is a form of feedback, so any component in this path must degrade audio quality, especially if an electrolytic is used...
Old 26th April 2007, 01:44 PM   #4
No you must provide a bootstrap cap. If you don't the amp will not be able to swing 100% positive and you will get a negative DC at the output when you play at loud volume.
The TDA7294 uses two n-channel mosfet at its output. The output mosfets need a voltage at its gate some volts above the output voltage. If the upper mosfet is to supply an output voltage at or near the supply voltage, the gate voltage has to be some volts above the supply voltage.
It uses the clever bootstrap trick that uses the alternating output signal and rectifies it internally to a voltage above the supply voltage.
If you search the net for bootstrapping in amplifiers I'm sure you'll get better understanding of what the bootstrap cap does.
space
Old 26th April 2007, 01:53 PM   #5
OK thanks for the explanation !
So if I understand you right, I need a 22µF or more cap in this place, and its quality is not a huge concern so a large electrolytic should do the trick.
I've just tried using a wire in place of the cap, and I get -32V DC offset at the output. Didn't try leaving it disconnected, I've read somewhere it could blow the IC...
P3A Bootstrap and NFB Capacitors christian.lenci Solid State 16 23rd December 2008 04:36 AM
Another thread regarding CCS vs BOOTSTRAP Nico Ras Solid State 83 7th December 2008 12:00 AM
Why bootstrap? peranders Solid State 52 27th December 2007 04:25 PM
Page generated in 0.07243 seconds (81.58% PHP - 18.42% MySQL) with 10 queries
