Old 23rd April 2007, 02:58 AM   #1
Default Need advice for a 4 channel amp
I need to build a fairly high powered 4 channel amp for a project.
I have some parts from a 6x100W Kenwood receiver, but I can't get data sheets for the output IC's from Sanyo (STK413-220A)
I'm thinking of using 4 LM3875 IC's, but I really need around 100W RMS into 8 ohms per channel. Are there any IC's with the simplicity of the LM3875, but with a bit more power capacity?
I have parts salvaged from the receiver to build a power supply capable of about +/- 50 volts and plenty of current.
Old 23rd April 2007, 03:20 AM   #2
es44 is offline es44  Denmark
es44's Avatar
Don't know if it's of any help for you, but i've seen the datasheets for your output-modules being posted on http://www.sharefx.com/index.asp?tab=today
Best regards
Ebbe
Old 23rd April 2007, 04:04 PM   #3
impsick is offline impsick  United States
impsick's Avatar
lm3886 have a bit more power. lm4780 is even more. if u need a 100w go with the 4780
"Nothing happens for a reason. There are just reasons why things happen." Quote me on that. http://stores.ebay.com/AudioGrade?_rdc=1
Old 23rd April 2007, 04:38 PM   #4
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
Are you just trying to match the Kenwood specs of 100Wx6ch? Realistically, you probably won't need 100W per channel. Anything in the range of 10-50W (with low THD) will probably be just fine.
As far as the IC goes, do you mean the STK413-020A? Sanyo is saying it will be discontinued the end of May this year and the replacement or similar product is the STK416-120E.
http://www.semiconductor-sanyo.com/p...f_e/EI0019.pdf
ampslab.com has datasheets for some of the other Sanyo STK parts: http://www.ampslab.com/components_stk.htm
Brian
Old 23rd April 2007, 05:08 PM   #5
if you can find the stk 4044ii(100watt into 8ohm) or stk4046(120watt into 8 ohm) or 4048(15o watt into 8 ohm.THD 0,008%) but only in stock..the datasheets are still available.
i have just see the 4044ii and 4046 in my town with 20euro(4044) and 30euro(4046)...and i have built a 2 channelpower amp with stk4044ii,it's quite good chip...
p.s. sorry for my English...
Old 1st May 2007, 10:58 PM   #6
The LM4780 looks like a great chip to try. I could buy 4 of them and have a 4x120W amp, and the transformer I have should be big enough to run all 4 channels without trouble.
What I am actually doing is building an amp for my digital theatre organ, which has two stereo "chambers", hence the need for 4 channels.
I am not looking to blow the windows out, just want lots of headroom in the amp. It will be driving a pair of Cerwin Vega SE 12" floor speakers, and a pair of Peavey 115PS 15" floor speakers with electrovoice EVM-15B Proline woofers. Both sets of speakers are 8 ohms.
Old 4th May 2007, 08:40 AM   #7
sukyone is offline sukyone  Thailand
sukyone's Avatar
Send a message via AIM to sukyone Send a message via MSN to sukyone Send a message via Yahoo to sukyone
TDA7294 Chip looks like for thai project .
But power supply ( transformer ) can
support for 400 VA
Old 4th May 2007, 09:21 AM   #8
lm4702 will work on +-50Vdc and more.
It will drive 8ohm speakers with single or dual output devices.
It can drive 4ohm speakers with dual or triple output devices.
It's not a single chip solution but offers many of the chipamp self protection features.
The datasheet is very comprehensive.
One note of caution, don't use integrated darlingtons to reduce the semiconductor count.
regards Andrew T.
Advice sought on building multi-channel amplification jwillans Solid State 10 3rd March 2009 08:31 PM
3 channel lm3875 help/advice Tristanc1 Chip Amps 8 22nd January 2007 05:04 PM
Soliciting center channel advice to match my existing system Jason_AZ Multi-Way 1 17th March 2006 03:29 PM
Poster in Musical Instrument forum needs bridging advice on BrianGT 4780 advice moving_electron Chip Amps 0 16th February 2005 12:37 AM
need center channel advice Schmadic Multi-Way 3 19th August 2002 03:43 AM
Page generated in 0.09732 seconds (74.41% PHP - 25.59% MySQL) with 10 queries
