Old 22nd April 2007, 04:41 PM   #1
ebenai is offline ebenai  United States
Default Transformer
I purchased a Hammond transformer rated at 300 VA dual secondaries 25 v. When I measured I only get 12.5 from the secondaries. In looking at the datasheet: you get 25 if you wire the secondaries in paralel. Will I still be able to connect it to the rectifier board? Or should I try to exchange it for another one with 25 V " independent" dual secondaries. I'm a begginer.
Old 22nd April 2007, 06:07 PM   #2
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
A diagram showing how you have connected it all up, and where you are taking your measurments from, will (hopefully) help somebody to suggest a solution!
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 22nd April 2007, 06:38 PM   #3
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
Dual secondaries 25V usually means the transformer has two 25VAC secondaries. What you didn't mention is the primary configuration of your transformer. Does it have one or two primary windings and what voltages are they?
Since you're measuring half of the rated voltage on the secondary chances are your transformer has either a single 240V primary or two 120V primaries that you've wired in series. If the transformer has a single 240V primary you will need to get another transformer. If it has two 120V primary windings simply wire them in parallel, paying close attention to make sure they are wired in phase. The datasheet should provide a connection diagram.
Finally, be very careful when working around mains voltages. Take your time, triple check your wiring, and ask as many questions as you need to instead of toying around with it.
Brian
Old 22nd April 2007, 06:51 PM   #4
BudP is offline BudP  United States
BudP's Avatar
ebenal,
Perhaps you should go to Duncan amps and down load their free power supply simulation software to help you understand the circuit you are working with. This is a very accurate tool and easy to use.
http://www.duncanamps.com/psud2/index.html
It will eventually allow you to specify transformers in a very precise manner and also allow you to model the ripple characteristics you will get from any particular power circuit design.
Bud
Old 23rd April 2007, 02:22 AM   #5
Default Transformer diagram
I have a attached the diagram. With the primary windings connected in series I got 12.5 V from each secondary. With the secondaries in series I get 25 V but then I only have two cables to connect to the rectifier board instead of 4 (2 AC1 and 2 AC2). Maybe I purchased the wrong transformer.
HAMMOND 182T12
Primary 2 x117
50/60 hz
VA 300.
Old 23rd April 2007, 02:24 AM   #6
Hi ebenai.
According to this Hammond page http://www.hammondmfg.com/182.htm the transformer you have has dual 12VAC secondaries.
182T12
300
24V ct @ 12.5A
12V @ 25A
Dual
That means you'll only be able to get about 16VDC rails after rectification. You will need a different transformer if you want one with two 25VAC secondaries for about 34VDC rails after rectification.
Brian
Old 23rd April 2007, 02:24 PM   #7
kscharf is offline kscharf  United States
kscharf's Avatar
Default Now THAT'S a transformer!
Take a look at this tranny!
http://www.apexjr.com/new.htm (scroll down the page a bit to find it)
It's $45 and 40 POUNDS to ship! over 1000VA!!!!!!
Old 23rd April 2007, 07:35 PM   #8
Default Re: Transformer diagram
HAMMOND 182T12
Primary 2 x117
50/60 hz
VA 300.
Originally posted by BWRX
Hi ebenai.
182T12
300
24V ct @ 12.5A
12V @ 25A
Dual
There is something that does not add up between these two posts.
Do you understand the difference between parallel and series?
The hammond literature clearly states that the T12 is a 24V ct transformer.
That means there are ONLY three secondary wires. But their diagram shows dual secondaries.
The voltages measured by ebenai show 12.5Vac per winding.
But this is done with the primaries in series. These primaries add up to 220Vac but what are they fed from? 12.5Vac is suspiciously low for a 12Vac transformer. I would expect 12.7 to 12.8Vac when fed with the correct mains voltage. But, maybe mains voltage was a little low at measurement time.
Ebenai, please clarify what you have and what you are measuring.
regards Andrew T.
Old 23rd April 2007, 08:50 PM   #9
Default Re: Re: Transformer diagram
On the Hammond web page it states that the 182T12 is a dual secondary transformer. The "24VCT" in their series rating does cause confusion, but they don't mean that it is a center tapped transformer.
The primaries are 117VAC, so in series that's 234VAC. Feeding 120VAC into the primaries in series would yield about 6.2VAC on each secondary, or around 12.5VAC in series.
I agree that ebenai is confusing series and parallel wiring. Even so, if he has the 182T12 it will not give him the voltages he is looking for.
Brian
Old 23rd April 2007, 09:10 PM   #10
phn is offline phn  Sweden
phn's Avatar
The Hammond trafos have two secondaries. Tie two secondaries together and you have a CT trafo. The tied together leads become ground. There's nothing strange about that.
Using mains transformer as output transformer Elias Tubes / Valves 175 3rd November 2009 08:36 PM
Modulation transformer for a driver transformer? ironradio Tubes / Valves 6 28th December 2008 05:05 PM
filament transformer vs plate transformer contaxchen Tubes / Valves 10 14th January 2005 10:43 AM
toroid Transformer as power Transformer for tube tone Tubes / Valves 7 11th February 2003 08:57 AM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 04:36 AM
Page generated in 0.12254 seconds (82.61% PHP - 17.39% MySQL) with 10 queries
