Old 21st April 2007, 11:13 PM   #1
haziz is offline haziz  United States
Default Using 2 gainclones to create powered speakers.
Sorry. I am newbie at this, so excuse me if the question appears too basic.
Crossovers seem to be a factor in the lack of efficiency of speakers. Why can't someone create a preamp/active crossover that would then feed 2 (for a 2 way speaker) or 3 gainclone amps (for a 3 way) that would then directly drive the speaker’s drivers without any passive crossovers?
Some experimentation may need to be made to achieve proper balance between the drivers, but the gainclone appears to be an ideal candidate for creating powered speakers sans crossovers.
Thanks.
Sincerely,
Hany.
Old 21st April 2007, 11:31 PM   #2
Sonusthree's Avatar
Hi Hany and welcome to the forum,
Yes I agree it's a great idea and is quite common. They are called active speakers. Try a quick site search on active speakers and active crossovers and you should get a ton of useful stuff.
Best Regards,
Martin.
Old 22nd April 2007, 09:15 AM   #3
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Hany, you are quite right, the chip amp is an ideal part of an active speaker system. You can read about one such system here .
And another one here .
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 23rd April 2007, 03:41 PM   #4
Fenris is offline Fenris  United States
Alesis made a number of these modules. 8th order active XO with HF and subsonic filters. I'm using seven right now for various things. I also made my own 4th order 5 way XO for a friend (with 15 GCs), a 5 way 8th order for my home theater (also with 15 GCs), a two way second order for my guitar amp, and a three way fourth order for a set of line arrays.
Passive filters aren't that inefficient, they just have to deal with varying impedance and electromechanical responses that reduce their linearity.
Listen to the music through the stereo, not the stereo through the music.
Old 25th April 2007, 05:18 AM   #5
yusuf is offline yusuf  India
Send a message via Yahoo to yusuf
External noise could be an issue to tackle in active speakers. Output of preamplifier is typically very low (say few hundred milivolt) and will be more susceptible to noise compared to amplifier out. This might not be an issue when preamp and amp are in close proximity but in case of speakers where disstance is large, I see some problem.
Old 25th April 2007, 05:25 PM   #6
You don't need to put the amps in the same box as the speakers (I never do). Just have an active crossover and amp by your source. It means more wires running to the speakers, but I like the Neutrik multi-pole quick connects to make connection quick, secure, and idiot proof. If cost is a factor, inexpensive bannana plugs and jacks work well, just don't cross-connect the tweeters and woofers!
How many Gainclones can be powered off a single rectifier? AJ Bertelson Chip Amps 13 4th December 2008 09:19 PM
box replacement for powered speakers tilroh Multi-Way 1 12th May 2008 03:58 AM
Really Small Self-Powered Speakers Help??? brhoff Full Range 7 23rd February 2006 05:56 PM
Powered Multimedia Speakers with DSP bimbla Chip Amps 1 18th January 2006 02:35 PM
Looking to create my own cube satellite speakers...tang band the answer? jtbullet Multi-Way 16 23rd January 2005 03:40 PM
Page generated in 0.08857 seconds (70.66% PHP - 29.34% MySQL) with 10 queries
