| Chip Amps Amplifiers based on integrated circuits |
Hello all,
I have not posted much but have learned a lot by reading other posts on this forum. I recently constructed a GC amp using the LM3886. I used point to point wiring on the amp and the filters for a bi-amp system driving my OB speakers. I got a chance to make THD measurements on just the amp section, which most people would be interested in. Measurement instrument: ST1700B with a residual THD of .003% Max. Power @ 2khz into 8ohms 60W with 36V rails THD at 50W into 8ohms 20hz .006% 2khz .004% 20khz .007% Total noise: -91db I did not perform the tests into 4ohms because of instability at 4ohms. The amp goes into oscillation as soon as the 4ohms is switched in on all 4 channels. I have two channels driving a 4ohm load. The gain on the amps is 19. Does anyone think lowering the gain will stop the oscillation at 4 ohms? This is the same schematic as posted in the spec. sheet. The amp sounds very good and during listening I don’t detect an oscillation. I’m comparing the sound to vintage McIntosh, in some respects this GC sounds better. Although I don’t listen to the McIntosh on the same speakers. |
#2 | |
The LM3886 is supposed to be used at a gain of 20+. It is not unity gain stable, so lowering the gain probably won't help. Do you have a zobel on the output? Do you have a sufficiently robust power supply?
Listen to the music through the stereo, not the stereo through the music. |
#3 | ||
The datasheet actually says it is designed to be stable with a gain >= 10, so I imagine that a gain of 19 should be just fine. ![]() Quote:
I recently had a problem similar to what you describe, because I had done this. From what I remember I think it was OK in to a 10R resistor load (I don't have an 8R resistor, may have been stable there too), but when I tried a 4.7R resistor it burst in to oscillation. As soon as I separated the input ground from the Zobel ground it went away and has been fine since ![]() Just a suggestion! Hope you can follow what I am on about. |
#4 |
I do not have a Zoble on the ouputs. I am no driving into a xover, but directly to the drivers. Is there a universal Zoble to start with?
Thanks |
#5 | |
I think perhaps adding one might help? Worth a try. I have used a 2W 4.7R carbon resistor and a 100nF cap.I'm not sure if it matters if you're driving in to a crossover or not. Perhaps someone else can answer that one for you. Do make sure that you keep the Zobel return / ground separate from the input returns / grounds though. Mine goes to the power ground and seems to be OK. I run four wires from each amp back to a central point (in my case the disconnecting / loop breaker network). - The power ground / Zobel - The input ground for LM3886 stuff (i.e the resistor from input to ground, feedback loop resistor to ground etc) - The input RCA barrel ground tab - The speaker return It could be something else entirely of course, but it does sound suspiciously like the problem I had before With this grounding set up I don't get any (visible) oscillation, no hum and no buzz (at all, even right up close to the speakers), so I can only assume it's somewhere near good grounding!I know I am still a bit rubbish at explaining, sorry! I think you should be able to solder this resistor and cap across the speaker terminals on the amp (and from what I gather it might actually be better to this). I have mine on the PCB. Something like this... PHP Code:
#6 |
What voltage were you useing at 4 ohms?
#7 |
Nordic, I'm using 36v rails if that is what you mean.
#8 |
Are you using a 4 ohm power resistor or a 4 ohm speaker for your load? I mean when it is oscillating?
#9 |
Sorry about the confusion, I was working off of old memory. Gain should be fine at 19. Adding a zobel can't hurt stability. A good place to start for values is somewhere between 2 and 5 ohms and a 0.1uF cap. Most people put it on the circuit board, but some (usually those who do P2P wiring) will put it across the output terminals of the amp. Either's fine.
A zobel in a crossover network is designed to work with the high inductance of the driver and give a constant impedance throught the crossover region. If the impedance is not constant, then the crossover components will only be correct at a single resistance, but will be incorrect as the frequency (and hence impedance) changes. A zobel counteracts the rising impedance due to the driver's inductance and creates a more constant impedance. A zobel on the amp is slightly different. If you assume that a properly designed loudspeaker will have a crossover that will keep the impedance relatively close to constant, then the zobel will have a fixed resistance to work with. It will then form a damped RC network (sometimes refered to as a snubber) that will bleed off high frequency energy (first order f3 pole of approximately 200KHz given 8 ohm speaker load and 0.1uF). Also, 36v might be a bit high to use with 4 ohms. There's a download from National that helps with designing power supplies for chipamps.
#10 |
You violated one of the boundary conditions when you used the LM3886 with a low impedance load and high rail voltage. the heat sink gets impossibly large (at least for non-forced air convection) at 4R/36V
use National's on-line calculator: http://www.national.com/appinfo/audi...gn_Guide15.xls |
| New T-Amp measurements | Pano | Class D | 12 | 14th March 2006 11:32 AM |
| Home Made Tubes?? has anyone made one, is it possible?? | John Biles | Tubes / Valves | 7 | 11th December 2005 01:29 AM |
| SW measurements | Grandma´s_SUB | Everything Else | 9 | 10th January 2005 01:34 PM |
| GC Measurements | lgreen | Chip Amps | 26 | 31st July 2004 09:02 PM |
| Measurements? | panos29 | Multi-Way | 3 | 20th April 2003 05:07 PM |
| Page generated in 0.12440 seconds (81.92% PHP - 18.08% MySQL) with 10 queries |
