LM3875 / T-Amp 5066 / 41Hz Amp 32 for THIS project?
Old 3rd May 2007, 01:52 AM   #11
judtoff is offline judtoff  Canada
I've only used passive radiators in suboofer applications, however I'd imagine they could be used the same in the 3 way. I can try to help, but it would be best to take my advice with caution.
The added cost is a downside, have you looked into different companies for passives? Even cheap active drivers can be used...they must have enough xsus. Then just add mass to the cone to tune it(easiest way is to remove the motor assembly and epoxy lead shot to the VC)
Edit:
They Daytons add $30bucks for the two(they suggest 2 8's per 8 activer driver, I think one will suffice) ...well worth the low end gained IMHO. Whats your internal dimensions so I can check out some stuff in WinISD?
Old 3rd May 2007, 05:52 AM   #12
jonkun227 is offline jonkun227  United States
jonkun227's Avatar
1 cubic foot, give or take a few inches. I have not compensated for the volume of the cones or the electronics, however. And I will be replacing the power brick with a battery, maybe two smaller batteries to even out the size and weight.
- Jon
LM3875 / T-Amp 5066 / 41Hz Amp 32 for THIS project?Hide this!Advertise here!
Newbie project - LM1875 or LM3875 redrum.42 Chip Amps 11 19th March 2009 05:38 PM
Advice on how to start a LM3875 amp project fatbob Chip Amps 12 8th April 2008 04:15 AM
LM3875 - newbie gainclone project Grandma´s_SUB Chip Amps 32 14th May 2007 07:49 AM
SI 5066 Input Cap Option Panelhead Class D 10 24th June 2005 06:15 AM
