Go Back   Home > Forums > General Interest > Car Audio
Old 6th April 2007, 12:26 AM   #1
Default Weird Amp Problem
I'm running a set of Polk SR 6500's off of a bridged Alpine Alpine MRV-F345. I have yet to get it professionaly tuned but what is making me scratch my head is when played loudly enough or songs with a lot of bass only one woofer will bottom out. I have yet to play it loudly enough to get the other woofer to bottom out. My first assumption was a problem with the speaker, so I switched the channels on the amp and the problem switched to the other speaker. So it's definitely not the speaker, all settings on the amp are the same for both channels. So could this be an issue with the amp? I bought it brand new from an authorized dealer so it seems like this is a weird thing to have happen but it's not the speakers. I don't have the luxury of testing out another amp but I've switched the speakers around to make sure it isn't the way they've been installed and it isn't the speakers. I'm tempted to just get a JL 300/2 and ditch the Alpine as I have a 500/1 running my sub. Any thoughts would be appreciated.
Also I've tried switching the RCA cables to see if maybe it was the HU but the right speaker still was the one bottoming out.
Old 6th April 2007, 12:38 AM   #2
Boris_The_Blade's Avatar
Just a hunch...take a meter and measure if there is any DC voltage on the amp outputs. Then post back with your findings.
Old 6th April 2007, 06:23 AM   #3
impsick is offline impsick  United States
impsick's Avatar
are the polks dual voice coil? i would guess you covered this already but are terminals on the subs correct.
"Nothing happens for a reason. There are just reasons why things happen." Quote me on that. http://stores.ebay.com/AudioGrade?_rdc=1
Old 6th April 2007, 06:54 AM   #4
heres one way to level the outputs of the channels. we always had to do this when running tow sub amps to different woofers that way one doesnt blow and the other be fine. disonnect your speakers. take a volt meter and put one on the positive and ine on the negative output terminals. put the meter on ac voltage. take a test tone cd. (sine waves) and play a track on reapeat at about 60-70 hz. start turning the stereo up like this to the point to where you got the distortion from the speaker. take that voltage and do it to the other channel also. ajust these levels accordingly to get the same output voltage ac turn it back down, plug the speakers back in and your stereo will be perfectly in balance.
weird problem sberube Solid State 15 22nd October 2008 06:27 PM
weird hum problem audiopro Tubes / Valves 4 31st August 2008 08:16 AM
NAD 306 weird problem Juko Solid State 1 4th May 2007 08:21 AM
Weird PSU problem phn Power Supplies 8 6th February 2007 02:42 AM
Weird amp problem Etnoo Car Audio 5 22nd August 2006 06:26 AM
Page generated in 0.07230 seconds (83.25% PHP - 16.75% MySQL) with 10 queries
