HELP, HELP Radio install needed?? I messed up
My OEM radio has the 92 - 99 amplified system harness. Thinking i was doing all right, i bought a 6 disc changer, but payed no attention to the pin out of it. This new readio has the 2000 - up harness. See pics below.
I can make the conections with the following kits of Metra:
which look like this:
My current one
The new one
However i still have questions>>>>>
If you see the picture of the new deck:
what is a shield ground. I need to connect this without problems.... Also my old deck has 1 power antenna, the new one has 3 power antennas, what do i do with the rest.
The rest i can pretty go by colors..... Thanks in advance...
